Sprinkler is on during rain
Wahid Ameni
更新時間 2020-03-14 00:12:38 UTC
瀏覽: 4578   回覆: 1
Carlo D'Ippolito
更新時間 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
瀏覽: 5091   回覆: 1
Claude Bedarride
更新時間 2020-02-29 14:28:34 UTC
瀏覽: 4390   回覆: 1
new dripping system using Pixie and Whisperer
Markus Matula
更新時間 2020-02-20 08:52:39 UTC
I am in the process of designing my dripping system for my beach house in FL. I am thinking about using 2 Pixies and several Whisperers. I have several questions: 1) What happens when the WIFI is down? Does Pixie turn watering off/on on its own? 2) Does Pixie skip a watering cycle when raining? 3) Are the Whisperers connected to the Pixie and App in that the humidity information guides the amount and frequency of watering? 4) What is the recommended soil humidity for new planted palm trees? Thanks, Markus
瀏覽: 4972   回覆: 1
Watering
Tim Foster
更新時間 2019-12-14 13:23:21 UTC
I have my first period of rain coming up, so the smart schedule isn't planning on watering until Christmas Eve. Since getting the sensors working properly I've been very happy with the smart watering, but the rain predictions here tend to be a bit sketchy. As my system is saying it won't water because there is rain expected, does it automatically adjust itself and water if the predicted rain doesn't arrive?
Also, I have it set to not water if expected rain is 5mm. What is the difference in this context between expectation and forecast?
瀏覽: 4690   回覆: 1
Sangjin Lee
更新時間 2019-10-17 03:41:11 UTC
瀏覽: 4968   回覆: 1
Weird watering plan
Manuel Roca
更新時間 2019-10-12 11:34:00 UTC
瀏覽: 4684   回覆: 1
Tony D.
更新時間 2019-09-24 21:08:17 UTC
Hello everybody,
瀏覽: 5009   回覆: 1
watering sequence
Gérard GALBOIS
更新時間 2019-08-26 18:23:46 UTC
It is unfortunatly not possible to change  in which ordre the watering will act.
for exemple I need to water zone 5 after zone 7 because zone 7 is at a higher level than the electro valve and remaining water pressure, after watering is stopped,  is to strong and prevents the valve to close . by watering supplemantary  zone 5 which is lower the pressure diminishes ans the valve of zone 7 closes..
瀏覽: 4836   回覆: 1
How does a whisper sensor work with a drip system?
L F
更新時間 2019-08-25 23:46:33 UTC
I have a couple whisper sensors monitoring my lawn and drip system.   I understand how they can monitor the soil in my lawn but I’m wonder how the whisper works on my drip system as it doesn’t see the moisture that’s added to the soil(the emitter isolates the water to the plant) or the rate the plants use it like the one in the lawn does.  I’m assuming it’s just estimating like the Netro would on it’s own.  Is there much value to using a whisper on a drip zone?
瀏覽: 4887   回覆: 1
Smart watering once a week?
Andrea D.
更新時間 2019-08-22 05:51:16 UTC
Hello there,
I'm new to netro and I tried to setup smart watering but the data I provided it will do it just once a week.
How is it possible? Is it safe to water just once a week?
瀏覽: 4705   回覆: 1
Unexpected smart schedule
Tony D.
更新時間 2019-08-12 09:35:56 UTC
- zone 1: 6:00 16 min.
- zone 2: 6:17 15 min.
- zone 1: 6:46 16 min.
- zone 2: 7:02: 15 min.
UPDATE
Thank you in advance,
Tony
瀏覽: 5079   回覆: 1
Runs for 9 hours at a time
Cindy Luvender
更新時間 2019-08-07 00:27:20 UTC
瀏覽: 4813   回覆: 1
itsthesun
更新時間 2019-08-06 20:42:23 UTC
瀏覽: 4899   回覆: 1
water amount
Gérard GALBOIS
更新時間 2019-07-31 05:37:55 UTC
瀏覽: 4608   回覆: 1
30 minutes = 10 minutes X 3
Paul Como
更新時間 2019-07-27 11:49:20 UTC
How do I set my program to run each zone for 30 minutes each, but water 10 minutes 3 times each.  I thought this used to be an option, but I don’t see it.
瀏覽: 4539   回覆: 1
Whisperer and smartzone configuration
更新時間 2019-07-19 13:45:19 UTC
I have set up all the zones with the whisperers. And there is something I do not understand.
One of the zones usually get flooded in autumn because the type of soil retains lots of water.
But the whisperer and the smart zone is saying that the zone has to be watered more time than the other zones.
My question is if the whisperer adapts the irrigation schedules and the time is watering per zone. Depending on the moisture, weather conditions  and type os soil.  It is clear that the soil type determines how much and how often to water.
Here in the following link (https://www.netrohome.com/shop/products/whisperer)says that "Netro accurately measures the water capacity and drainage rate of your soil, making sure your soil always receives the perfect amount of water at the perfect time."
That is fine, but it is confusing that in the app I can still define the type of soil.
A second question I have is that I can define the watering strategy (Regular, ECO etc...) I want to know if the whisperer and the controller will notify me if I have to change the strategy based on the weather conditions and the type of soil, plants etc...
Any idea?
瀏覽: 5603   回覆: 1
Doug Clark
更新時間 2019-07-07 18:06:07 UTC
This isn’t AI!
瀏覽: 5079   回覆: 1
Reset Moisture Level
firewally
更新時間 2019-07-06 14:06:03 UTC
瀏覽: 5084   回覆: 1
Forecast provider for Italy
Gabriele Gianello
更新時間 2019-07-03 11:53:03 UTC
瀏覽: 5376   回覆: 1
