Why no cycle soak setting?
更新時間 2023-07-08 19:56:33 UTC
瀏覽: 4137   回覆: 1
Pixie Z1
ke7vng
更新時間 2023-07-08 02:25:00 UTC
瀏覽: 3773   回覆: 1
Not enough watering
Manuel Herbst
更新時間 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
瀏覽: 4187   回覆: 1
Cambio días de demora.
Lino
更新時間 2023-07-03 06:35:04 UTC
瀏覽: 3850   回覆: 2
更新時間 2023-06-27 08:48:51 UTC
瀏覽: 4128   回覆: 1
更新時間 2023-06-26 12:06:15 UTC
  1.  it's raining or
瀏覽: 4115   回覆: 1
Zones not watering
joefil
更新時間 2023-06-22 16:54:38 UTC
Your help is appreciated
瀏覽: 3924   回覆: 1
Start-end time not working
Fabio Silvestri
更新時間 2023-06-21 05:20:31 UTC
瀏覽: 4166   回覆: 3
更新時間 2023-06-19 09:25:40 UTC
瀏覽: 4269   回覆: 2
更新時間 2023-06-10 17:50:24 UTC
瀏覽: 4056   回覆: 1
更新時間 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
瀏覽: 16163   評論: 12
Custom sprinkler flow rate
Jure
更新時間 2023-06-01 14:42:27 UTC
瀏覽: 4129   回覆: 1
New grass from seed
D Berggren
更新時間 2023-05-31 01:11:58 UTC
瀏覽: 3794   回覆: 1
Rotor head
Sjors Janssen
更新時間 2023-05-25 19:15:07 UTC
I've just been using a Netro Spark to water my garden. I have set up 3 zones. Two of these zones have a rotor head sprinkler. However, they don't cover the same area. One of them rotates over 90 degrees. The other rotates 180 degrees. So I think the rotor head that covers the 180 degrees needs to run double the time of the 90 degree one. How can I set this? I've set the sqm for each head, but smart irrigation used the same times for both.
Kind regards,
Sjors
瀏覽: 3756   回覆: 1
Update the irrigation routine according to the updated weather forecast
Luis T
更新時間 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
瀏覽: 4143   回覆: 1
Bruno
更新時間 2023-05-10 22:41:29 UTC
瀏覽: 4104   回覆: 1
Whisperer GPS error
Guido Minciotti
更新時間 2023-05-10 15:11:55 UTC
瀏覽: 3958   回覆: 1
Alexa
Federico Gietz
更新時間 2023-04-30 15:28:52 UTC
瀏覽: 3708   回覆: 1
Jim
更新時間 2023-04-24 17:38:25 UTC
瀏覽: 4004   回覆: 2
Matt Ward
更新時間 2023-04-14 13:57:11 UTC
Matt
瀏覽: 3997   回覆: 3
