Can’t open netro app
Marcos Sanz
更新時間 2023-06-12 16:35:22 UTC
瀏覽: 4107   評論: 1
A single rain day
Rob Nelson
更新時間 2023-07-15 11:22:50 UTC
瀏覽: 4394   評論: 1
Brian Brun
更新時間 2023-08-02 01:14:30 UTC
瀏覽: 4416   評論: 1
Please issue a good manual.
Mark Menzhausen
更新時間 2023-08-27 15:04:55 UTC
瀏覽: 4997   評論: 1
Irrigreen sprinklers
更新時間 2023-09-09 08:34:33 UTC
Combining with the whisperers
https://irrigreen.com/
瀏覽: 4601   評論: 0
Alexa Skill
Louise Brinkman
更新時間 2023-10-13 01:00:17 UTC
瀏覽: 4790   評論: 3
更新時間 2023-11-07 06:10:16 UTC
瀏覽: 5140   評論: 0
Good results
R C
更新時間 2023-10-24 18:55:29 UTC
瀏覽: 5934   評論: 2
更新時間 2023-11-07 13:27:20 UTC
瀏覽: 37175   評論: 1
Thresholds
Shady Trails
更新時間 2023-12-23 16:16:15 UTC
瀏覽: 4742   評論: 3
Richard
更新時間 2024-01-07 22:48:08 UTC
UPDATE 8/1/2024
UPDATE: 5/1/2024
UPDATE: 4/1/2024
ORIGINAL:
瀏覽: 5136   評論: 11
更新時間 2024-09-19 03:30:21 UTC
瀏覽: 20659   評論: 3
更新時間 2018-06-04 12:37:29 UTC
1.Year One
3.After the first week or so
4.Years Two to Three
5.After Year Three
Helpful Tips
Before you water:
瀏覽: 10490   評論: 4
Fixing App "Contact Us" feature not working for Andorid
更新時間 2019-07-15 01:37:42 UTC
To the Netro android users,
Our Netro app crashes for android on sending messages though Settings->Support->Contact Us suddently. Our R&D are fixing this issue and we expect to have the fixes in place in a few days. We are sorry about the inconvenience.
If you have any questions, please write to us support@netrohome.com and we will make sure to deliver technical support in short time.
Thanks again for your support and trust.
瀏覽: 6967   評論: 0
更新時間 2022-04-24 01:45:07 UTC
瀏覽: 9366   評論: 1
How to Water Trees and Shrubs
更新時間 2018-06-04 10:07:08 UTC
1.How to Water Shrubs
2.How to Water Trees
Don't wait for the plants to tell you with wilting and leaves dropping off. Then youll just be watering to keep the plants roots alive so it may possible come back later. Inspect the soil. Dig around with your hands, soil probe, garden trowel, or shovel. Youll be able to tell quickly how far down you are actually watering.
Resources
瀏覽: 10441   評論: 3
更新時間 2018-06-04 10:03:46 UTC
References
瀏覽: 10023   評論: 0
更新時間 2023-11-07 06:09:05 UTC
Then you should put Sprite in "paused" mode just in case some one (for example the kids) accidentally starts a manually run from the app. To put Sprite in "paused" mode, you can go to the Home page->"Enabled".
瀏覽: 9359   評論: 1
Customization->set rain/temperature/wind threshold to skip watering
更新時間 2018-10-13 06:19:08 UTC
Netro automatically creates dynamic watering schedules according to local weather, so if you turn on the smart zone feature for your zone, season adjustment will be made with smart watering schedules according to weather.
There are different types of weather restrictions: rain, temperature and wind.
By default, If you turn on the smart zone feature, Netro will skip the schedules (including manual schedules from user programs) when there is a chance of significant rain(>0.2inch).
The default threshold to skip watering when temperature is too low is 0 Celsius degree (32 Fahrenheit) for all the Netro controllers.
You can now customize rain, temperature and wind threshold through Settings->Preferences.
瀏覽: 7759   評論: 0
更新時間 2023-06-09 06:07:25 UTC
2.Smart watering: Level basic
3.Smart-zone feature disabled
瀏覽: 16163   評論: 12
