更新時間 2020-06-22 07:37:55 UTC
瀏覽: 7673   評論: 5
Installed perfectly
Lakeside Gardens
更新時間 2020-07-12 14:57:53 UTC
And we are off and running.   Whisper went in the ground and started reporting right away.  Would be nice to connect it to my Ambient weather station as well.
瀏覽: 6262   評論: 1
Addiel Isaac Moldes
更新時間 2020-07-19 11:43:54 UTC
瀏覽: 6002   評論: 2
Maximum wire distance between controller and valves
更新時間 2021-01-16 14:20:49 UTC
Below is a chart indicating the maximum wire runs that can be used when installing AC solenoids and valves.
22 AWG: 600 feet
20 AWG: 700 feet
18 AWG : 850 feet
16 AWG: 1300 feet
14 AWG: 2000 feet
瀏覽: 5832   評論: 0
