i have problem with netro sprite 6
Nguyễn Vinh
更新時間 2022-01-06 04:51:41 UTC
I am a distributor of netro products in Vietnam market
My customer just sent back a product with a burnt electronic device inside (pictured). can you tell me what the possible reason is and how to fix it.
- 220V (stable) power supply
- no lightning or explosion
- Full safety equipment to protect electrical equipment when there is a problem.
Thank you very much
瀏覽: 4347   回覆: 1
No restrictions set, yet program is skipping because of user restrictions
alan.ashby
更新時間 2022-01-02 11:40:53 UTC
I have no restrictions set, yet the app is indicating that restrictions are set and scheduled days are being skipped when they should not be.  Please see app screen shots.
瀏覽: 3960   回覆: 1
2 programs scheduled on one day
paul hewitt
更新時間 2021-12-24 05:21:45 UTC
I added an afternoon program after the morning one had run to run daily as very hot over next few days. After setting it up I went into schedule to make sure it was there and all that appears on the day is the morning schedule with a yellow triangle with exclamation mark instead of the usual tick to say it was done. I did see it running the morning schedule.
Why doesn't the afternoon schedule show up as well as the morning one?
Paul
瀏覽: 4294   回覆: 1
Lyndon Whyatt
更新時間 2021-12-22 19:53:57 UTC
I reset my Whisperer sensor by following the reset instructions and on restart it flashed white. I added the sensor via the app but it didn’t produce a WiFi signal and I couldn’t connect to it in Settings on my iPhone. After a while it flashes dark blue.
What is happening and how can I fix it?
瀏覽: 4490   回覆: 1
davejburton@gmail.com
更新時間 2021-12-16 01:35:31 UTC
Howdy!
瀏覽: 4176   回覆: 1
I have problem with netro pixie
Nguyễn Vinh
更新時間 2021-12-01 06:33:51 UTC
My Pixie can't enable manual mode, when i manually launch the app it says "Pending" and it doesn't work
瀏覽: 4299   回覆: 1
Whisperer temperature and moisture readings are way off
Andrew
更新時間 2021-11-28 00:35:49 UTC
I recently bought a whisperer and for the first few days it worked perfectly but now it consistently reports the temperature as being over 300 degrees celcius, and soil moisture at 0% even while it has been raining here for a week.
I've tried relocating the whisperer and deleting and re-setting it up twice but get the same result.
I'm unsure what else to try. Does anyone have advice or a fix for issues like this?
瀏覽: 5036   回覆: 2
Roger Prunonosa Duran
更新時間 2021-11-22 10:30:32 UTC
They haven’t lasted much…
瀏覽: 4935   回覆: 2
Yellow triangle error
James Mershon
更新時間 2021-10-06 12:23:33 UTC
瀏覽: 4172   回覆: 1
更新時間 2021-10-03 16:59:12 UTC
瀏覽: 4672   回覆: 1
Can't get our Netro to reset
Neil Hobbs
更新時間 2021-09-13 20:54:12 UTC
瀏覽: 4253   回覆: 1
Power Supply
Jason Willis
更新時間 2021-09-12 12:27:04 UTC
Jason Willis
瀏覽: 4584   回覆: 1
Connexio
Gerard Coulombe
更新時間 2021-09-12 11:02:25 UTC
Help needed
瀏覽: 4071   回覆: 1
Program Not Running
Wally Carnes
更新時間 2021-09-09 02:37:52 UTC
瀏覽: 4713   回覆: 2
Whisperer not working right.
vkanaga
更新時間 2021-08-27 23:46:35 UTC
瀏覽: 4464   回覆: 1
Michael Gough
更新時間 2021-08-21 14:21:39 UTC
瀏覽: 4346   回覆: 1
Daniel Encinas
更新時間 2021-08-18 06:17:45 UTC
Hi all,
Thanks a lot,
Daniel
瀏覽: 4384   回覆: 1
Sensor doesn’t work correctly
Paolo Sciarappa
更新時間 2021-08-14 20:06:25 UTC
The graphic is very poor.
 Any suggestion.
Thanks Paolo
瀏覽: 4346   回覆: 1
One zone not working
S Yarrish
更新時間 2021-08-06 00:50:19 UTC
瀏覽: 4223   回覆: 1
更新時間 2021-07-26 16:02:28 UTC
瀏覽: 4670   回覆: 2
