Yellow triangle with ! Inside
Michael Pakalolo
更新時間 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
瀏覽: 5079   回覆: 1
Zones run at the same time
Rich Christenson
更新時間 2019-08-15 11:05:09 UTC
瀏覽: 5467   回覆: 3
Low pressure in zones
Hussein Diab
更新時間 2019-07-29 16:36:31 UTC
瀏覽: 5003   回覆: 1
Water stops running before the cycle is over
sgschrank
更新時間 2019-07-18 18:03:03 UTC
Recently I have been having issues with zones 5-8 stop watering before the cycle is over, but keeps counting down and moves to the next zone and does the same thing. I have tried resetting the unit, re-linking the wifi, but doesn't seem to make a difference. Help!
瀏覽: 4926   回覆: 0
更新時間 2019-07-12 15:05:29 UTC
瀏覽: 5619   回覆: 1
Rod Timby
更新時間 2019-07-11 18:14:39 UTC
瀏覽: 4933   回覆: 1
Rod Timby
更新時間 2019-07-11 18:09:47 UTC
瀏覽: 4822   回覆: 0
Whisperer Test
Dan Leng
更新時間 2019-07-10 18:29:27 UTC
瀏覽: 5688   回覆: 2
更新時間 2019-07-07 14:40:49 UTC
瀏覽: 6254   回覆: 1
Saurik
更新時間 2019-07-04 07:12:42 UTC
瀏覽: 5215   回覆: 1
更新時間 2019-07-01 16:32:17 UTC
瀏覽: 5485   回覆: 1
internet may not be available
Bruce Vermeulen
更新時間 2019-06-30 18:31:02 UTC
Bruce
瀏覽: 4989   回覆: 0
WiFi connection
Andrew
更新時間 2019-06-27 00:49:26 UTC
瀏覽: 4829   回覆: 0
Remove whisperer
Dan Orms
更新時間 2019-06-25 16:17:24 UTC
瀏覽: 5379   回覆: 1
Disconnecting Constantly
Kate Whelan
更新時間 2019-06-09 18:05:15 UTC
My Netro Smart Sprinkler Controller, WiFi, Weather aware, Remote access, 6 Zone, Compatible with Alexa disconnects CONSTANTLY from the app/network and I’m about to put back on our old school controller. Today it disconnected IN THE MIDDLE of watering the lawn while I was feeding/putting my baby down for a nap and it ended up watering for 28 mins, flooding my backyard. Ugh.
Any tips on fixing this? I do not have intermittent internet or power issues. Is there a hardware update? Aside from this, I LOVE it - but this is kind of a deal killer for me. I plan to call customer service on Monday, but thought I’d check here for tips to see if I can fix it sooner.
瀏覽: 5822   回覆: 1
Not watering on any zone
A Miller
更新時間 2019-06-02 18:39:10 UTC
The sprite worked perfect for about 3 weeks. Went out of town for a week, during that time it snowed for the entire duration of my trip. The unit worked as it should and didnt water. However when it should have picked up its schedule after weather cleared it did not. It will not run its zone at all. I have checked the resistance on all zones solenoids and they are fine at 28 ohm. I reconnected my old hunter system and all zones worked properly with that controller. So whats the next step?
瀏覽: 8770   回覆: 1
Constant Blinking
Seth McDonald
更新時間 2019-05-31 00:32:04 UTC
My device appears to be connected and working, but I noticed the light on the unit is blinking constantly.  Is it supposed to be doing that?
瀏覽: 5191   回覆: 1
Don’t Stop !!
Eduardo Ariste
更新時間 2019-05-26 11:27:42 UTC
瀏覽: 4966   回覆: 1
jpmeyer81
更新時間 2019-05-19 15:04:11 UTC
瀏覽: 5381   回覆: 1
Roianne Cox
更新時間 2019-05-19 13:52:50 UTC
瀏覽: 4982   回覆: 1
