Smart schedules
Vincent Coutinho
更新時間 2023-02-07 20:51:01 UTC
瀏覽: 4023   回覆: 1
API
更新時間 2022-11-18 11:22:08 UTC
瀏覽: 4186   回覆: 1
Gianluca Bus
更新時間 2022-11-03 12:03:59 UTC
Hi all!
Netro App vesion: 3.1.0
Netro controller hw ver.: 1.2
Thanks in advance.
Gianluca
瀏覽: 4028   回覆: 1
Water valve opened
Paolo Talamelli
更新時間 2022-10-23 10:52:29 UTC
瀏覽: 3950   回覆: 1
Sprite-6
Rockhead413
更新時間 2022-09-26 18:04:30 UTC
Vincent Devlahovich
瀏覽: 4266   回覆: 1
Watering during a restriction
Valeria Dp
更新時間 2022-09-20 20:26:21 UTC
Tonight at 2.30 my netro start to watering. I had to stop it starting a manual program and stop it because in the app there was no watering sign.
Then I put a restriction for 3 days and around noon netro starts to watering again. There was a lost wifi signal for a minute cause by a voltage drop.
Is it normal?
瀏覽: 4240   回覆: 1
Cannot reset Sprite
punyelroo
更新時間 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
瀏覽: 4366   回覆: 1
Karen Thompson
更新時間 2022-09-02 15:15:20 UTC
瀏覽: 4457   回覆: 1
A Gallo
更新時間 2022-08-29 14:28:38 UTC
瀏覽: 4222   回覆: 1
Clock on sprite
Rory
更新時間 2022-08-24 19:43:30 UTC
瀏覽: 3987   回覆: 1
Sprinklers run repeatedly
Sunil Sivanand
更新時間 2022-08-12 01:18:11 UTC
瀏覽: 4116   回覆: 1
Juan Brea
更新時間 2022-07-26 18:08:13 UTC
瀏覽: 4130   回覆: 1
Repuesto
Juan Pascual
更新時間 2022-07-23 08:12:17 UTC
Buenos días desde España
Mil gracias
瀏覽: 4579   回覆: 2
Zone won't shut off
chesh235
更新時間 2022-07-18 18:53:38 UTC
瀏覽: 4265   回覆: 2
Plant sensor
Miro D
更新時間 2022-07-14 10:42:35 UTC
瀏覽: 4126   回覆: 1
More data
Jim Shaffer
更新時間 2022-07-13 13:06:30 UTC
瀏覽: 4117   回覆: 1
Android devices logout issue
Wency Pan
更新時間 2022-07-12 06:35:45 UTC
瀏覽: 6172   評論: 1
Pump Problem
wvfox
更新時間 2022-06-28 16:18:58 UTC
Vance
瀏覽: 4132   回覆: 1
New Whisperer Issue
Alfonso Marin Salgueiro
更新時間 2022-06-24 15:15:07 UTC
Hello everyone from Spain.
Can somebody help me?
I attach a photo.
Thank you very much.
瀏覽: 4277   回覆: 1
更新時間 2022-06-19 17:14:35 UTC
Added information:
瀏覽: 5333   回覆: 4
