end Battery life?
更新時間 2022-06-15 13:23:27 UTC
瀏覽: 4213   回覆: 1
Tech support
Robert Dambrosio
更新時間 2022-06-13 00:41:59 UTC
瀏覽: 4539   回覆: 1
Netro light
beppezhome
更新時間 2022-06-09 14:46:24 UTC
瀏覽: 4099   回覆: 1
James Berg
更新時間 2022-06-05 01:03:46 UTC
瀏覽: 4722   回覆: 1
Andy Ricco
更新時間 2022-05-31 06:12:27 UTC
瀏覽: 4455   回覆: 1
Sleeping mode
Fabrice GOUFFRAN
更新時間 2022-05-18 10:11:40 UTC
瀏覽: 6173   評論: 1
water valve does not work
Paolo Raviolo
更新時間 2022-05-03 15:55:47 UTC
I set up the pixie timer, everithing seems ok but the valve does not opens, nor with program nor in manual mode, no water at all.
can you help me?
瀏覽: 4046   回覆: 1
Pixie shows "communicating" and timer counting down but valve not open?
Douglas Ely
更新時間 2022-05-01 15:54:22 UTC
When trying to use the Pixie to manually water the garden, I go to the Netro app and select the pixie. It shows "sleeping", 99%charged. I then select "manual run" and set a time. The app then grays out and says "communicating" as the timer begins counting down my preset manual time but the valve stays closed. Why? When does it open?
瀏覽: 4809   回覆: 3
Location outside USA
Eduardo Prieto
更新時間 2022-04-30 09:45:16 UTC
I live in Spain and ubication selector do not let me specify my correcto location. I assume It is requieres to provide the Meteorological service the place where to predict weather, so if location is incorrect, the weather too and the watering planning is not optimized properly.
Please work It out un Next app releases.
瀏覽: 3977   回覆: 1
Incorrect rainfall accumulation
rwflower
更新時間 2022-04-29 16:35:33 UTC
I live in Katy Texas and have been using the Netro water controller in smart mode for over 2 years with no problems.  We received at least 1.5in of rain on the April 25, so I was dismayed to find my sprinkler system watering my yard on the morning of the 26th.  The rain graph in the app is showing 0.03in for the 25th and is clearly wrong.  I have tried changing to all the different weather providers, but the total rain accumulation doesn't change.  The frontal system that caused the rain passed over the entire area, so this is not a situation of local shower only affecting a localized area.
瀏覽: 4370   回覆: 2
Scott Gustafson
更新時間 2022-04-14 22:26:18 UTC
瀏覽: 4398   回覆: 1
idpitt
更新時間 2022-04-03 14:58:04 UTC
瀏覽: 4481   回覆: 1
metellusa@gmail.com
更新時間 2022-03-21 18:45:44 UTC
瀏覽: 4362   回覆: 1
Netro pixie in standby
mbhi
更新時間 2022-03-12 10:44:15 UTC
瀏覽: 4072   回覆: 1
Gabriele Cofano
更新時間 2022-03-02 12:45:59 UTC
瀏覽: 4097   回覆: 1
Interface
John Degolyer
更新時間 2022-03-02 05:58:45 UTC
瀏覽: 4619   回覆: 2
Duane Smith
更新時間 2022-02-16 21:58:22 UTC
Good Afternoon Everyone,
Duane
瀏覽: 4116   回覆: 1
whisperer off almost 1 month
更新時間 2022-02-16 17:01:49 UTC
seems that whisperer didnt collect data for almost one month!!, this is due to battery? we are in winter but it’s installed on a sunny place!! and app did no send alerts when this happens!!?
瀏覽: 4534   回覆: 1
Pixie smart timer battery not charging
Becky Aquino
更新時間 2022-01-23 00:57:20 UTC
Anyone have an issue with the pixie battery not charging from the unit using solar? My battery level is down to 19% and I live in Hawaii, lots of sun. Not sure if I did something wrong.
瀏覽: 4089   回覆: 1
Sensor sending wrong data
Mick Faulks
更新時間 2022-01-14 06:49:41 UTC
Hi have my whisperer installed in a garden bed, it saying 0% moisture when the soil is quite wet and it is saying temp is 200 C up to 380 C I have reset it many times but continues to give these readings.
瀏覽: 4348   回覆: 1
