ElctroValve don't sart
Francesco Merisio
更新時間 2024-05-02 20:19:07 UTC
Hy, i hava a problem.
When i start a irrigation cycle, only one Valve don't open, but when i start a test cycle from App, the same valve correctly open and start for few second the irrigation.
Why in the ccycke test the same valve it's ok and in the manually start don't go?
Idea?
grazie
瀏覽: 3866   回覆: 1
Timer and sensor data incorrect on PC web browser
Mart B
更新時間 2024-04-21 17:25:05 UTC
I had to replace a dead timer a while ago, it and my whisperer are working great in my iPhone Netro app.
But ... when I log into my Netro home on a PC, using MS Edge web browser, my current equipment is not there, it has all my old stuff that should no longer exist ... I checked and am definitely logging in as the same account on both iOS and PC. It is very weird.
Is there any way to get this corrected?
瀏覽: 3870   回覆: 1
Zone won't start watering
Homestead One
更新時間 2024-04-11 13:58:33 UTC
For some time one of my zones won't start watering. I have changed the valve with a new one but still won't start watering.
Any ideas? Thank you!
瀏覽: 3932   回覆: 1
Open Circuit Master Valve
Matt Ward
更新時間 2024-04-08 23:44:05 UTC
My system is not working. When I run a valve test, it shows all valves are normal but the master valve has an open circuit error. I have checked all the wires and there is not voltage at the wires at the valve itself. I used a volt meter at the Netro controller and there is no voltage coming out of the controller for the master valve. Any suggestions?
Matt
瀏覽: 4016   回覆: 1
weather scheduling
rafal72
更新時間 2024-04-02 21:10:48 UTC
Hi, Weather condition scheduling never worked and I've been using then Netro product for many years now. Currently both forecast & expectation are set at 0.1 threshold with skip (previous day, rainy day and next day). Weather station is set to NetroWeather and main app page is fairly accurate. Just today, it rained for most of the day and NetroWeather showed correctly "100% rain". Sadly, schedule program started anyway even though it was raining. I have changed weather provider, thresholds and nothing changes. This is very annoying to waste water, and I am looking for any tips how to mitigate this issue.
Cheers
Rafal
瀏覽: 4007   回覆: 1
My sprite system battery
jeffrey fischer
更新時間 2024-02-18 16:39:36 UTC
My netro app give me a Notification "Device thirst quencher Low Battery"
I took the device apart and can see, what looks like, a small battery on the circuit board.  Does this need to be replaced?  And if so, where do I purchase a new one?
瀏覽: 4011   回覆: 1
Spark showing error 1 on all solenoids
Mick Faulks
更新時間 2024-02-01 00:40:26 UTC
My Spark has stopped watering and is showing error 1 short circuit on every solenoid. I have tested each solenoid individually and they all operate disconnected from the spark. After multiple hard resets it started working correctly for a short time now it is saying all the solenoids are open circuit. I have tested all the solenoids and they are working perfectly.
瀏覽: 4029   回覆: 2
Clicking off before scheduled time
paul hewitt
更新時間 2023-11-24 01:07:07 UTC
This morning my retic was coming on the usual schedule but I noticed that it seemed to only be on for a few minutes instead of the set 30 mins.
The system said it was watering but it had turned off. I set a station manually for 10 minutes and after approx 4.5 mins it clicked off at the controller but the app said it was still running. I tried another station and it has the same issue ie it is set to run for 30 mins but clicks off after 4.5 mins but the app says it is still watering. I then waited for the next scheduled station to turn on at 8.50am and it clicked on as usual but after approx 5 mins it clicked off but app said it is still running.
I reinstalled the app and that didn't work so then did a hard reset but I still have the same problem.
I can't figure out why the controller is clicking off but the app says it is still watering.
Any ideas?
Paul
瀏覽: 4283   回覆: 1
Zone failure to run
Homestead One
更新時間 2023-10-09 08:30:37 UTC
Hi, I have one out of 4 zones who won't start watering. I have changed the valve and the problem still persist. I have checked the connections and the cables, all looks good. There is voltage.
Any ideea?
瀏覽: 4243   回覆: 1
Zone Failure
Ben Pittarelli
更新時間 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
瀏覽: 4056   回覆: 1
Whisperer 2 "serial already in used" issue
pridebowl33
更新時間 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
瀏覽: 4091   回覆: 1
Unrequested watering cycle
Claudio Polacco
更新時間 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
瀏覽: 4178   回覆: 1
Jacob Matheny
更新時間 2023-09-01 13:44:37 UTC
瀏覽: 4219   回覆: 1
Leandro
更新時間 2023-08-31 10:48:12 UTC
HI Support Team and All,
This wasn't written anywhere.
thank you all
Leandro
瀏覽: 4078   回覆: 2
Scott Yates
更新時間 2023-08-29 12:38:49 UTC
瀏覽: 4254   回覆: 1
Pixie
Charles Schatz
更新時間 2023-08-12 15:53:10 UTC
How do I synch my pixie without having to wait for the scheduled time?
瀏覽: 3865   回覆: 1
Netro Sprite 6 valve won’t stop
Alberto Casu
更新時間 2023-07-29 19:25:45 UTC
I just replaced my sprinkler controller with a new Netro Sprite 6.
Using both a programmed or a manual start, all valves don’t stop unless I remove power to the Sprite.
During a program, where I planned the zones to run sequentially, the zones activate one after the other without stopping and causing the zones to loose pressure and be unable to complete.
On the FAQ, it says to remove power to stop the zone, which actually stop all the watering, but this it totally unusable to me.
I am using the European version with the provided power supplier. I am based in Italy.
Can you please help?
瀏覽: 4347   回覆: 2
Netro - Stopped Working and won’t power up
John Loethen
更新時間 2023-07-25 14:04:38 UTC
Been a Netro customer for a while and pretty handy. I have three different Netro controllers and my oldest one just stopped working and won’t power up… I have verified the power at the outlet and have changed out the power supply with another 24v power supply that I know works. Still the controller will not power up.
Let me know if anyone else has suggestions.
John in Lincoln, NE
瀏覽: 3938   回覆: 1
misterhoff
更新時間 2023-07-25 03:11:25 UTC
瀏覽: 3789   回覆: 0
更新時間 2023-07-24 00:54:03 UTC
瀏覽: 4169   回覆: 1
