Zone 1 not watering
11807GFT
更新時間 2024-09-24 23:25:59 UTC
瀏覽: 3341   回覆: 1
Thomas Murphy
更新時間 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
瀏覽: 3354   回覆: 1
Smart watering not working
更新時間 2024-09-10 16:17:51 UTC
瀏覽: 3404   回覆: 1
Broken whisperer sensor
Jesús López
更新時間 2024-09-09 16:19:33 UTC
Hi everyone!
瀏覽: 3590   回覆: 2
Discrepancia APP y WEB
JM del Amo
更新時間 2024-09-07 13:06:53 UTC
瀏覽: 3397   回覆: 1
1 valve works, two don't
Phil Rubin
更新時間 2024-08-17 21:52:30 UTC
瀏覽: 3617   回覆: 1
Zone watering while disabled
Brian Paternostro Paternostro
更新時間 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
瀏覽: 3957   回覆: 2
Error E1
Simone Ragnolini
更新時間 2024-07-26 11:13:02 UTC
Ho, we need support, as we are having an issue as the app doesn’t activate watering. The control unot shows E1.
瀏覽: 3657   回覆: 1
La zona non si spegne
Gmultis
更新時間 2024-07-17 16:29:38 UTC
Quando collego la valvola la zona resta alimentata a 24 v anche quando finisce il ciclo. Quindi non smette di irrigare anche con la spia di colore verde.
Senza la valvola invece la tensione torna 0 volt.
Cosa può essere il problema
瀏覽: 3704   回覆: 2
Problem with irrigation time
Daniel Encinas
更新時間 2024-07-12 10:43:36 UTC
Hello, I have owned a Netro Sprite programmer for several years.
The problem I have is that it programs the phases intelligently and if it indicates that it has to water for 10 minutes. It only waters for about 1 minute but the app shows that it has watered for 10 minutes. The garden is drying out and I don't know what to do.
This happens to me in all irrigation phases. If I program it manually the same thing happens to me. If I try it twice, the second time it takes even less time to water.
I have connected the transformer directly to the phase, bypassing the programmer, and it works correctly.
Reviewing its problems section, I found a similar one in which it says to look at the 24 volt voltage. (which is correct, around 30 volt) and the resistance in ohms of more than 20 (around 30 ohmios). It also says that there the programmer has a recoverable fuse.
What can I do?
瀏覽: 3710   回覆: 1
Cannot find master solenoid valve
kvschlegel
更新時間 2024-07-06 22:46:35 UTC
None of the zones are watering when the app says it's watering. I measured each zone when active and each read 28 AC. When testing the resistance, the readings were jumping all over the place for each reading. This is leading me to believe there is an issue with the master solenoid valve. However, there is no wire that connects to the M slot on the controller. Looking around the house for any of the underground boxes, I have not been able to find the master solenoid. Attaching pictures of what I have found. Any help greatly appreciated.
瀏覽: 3978   回覆: 2
all connections good but sprite wont open any valves.
Douglas Ely
更新時間 2024-06-29 11:36:11 UTC
One day, the Sprite just stopped opening the zone valves. We tested and reconnected all the wires and deleted and re-installed the Sprite. Still no luck. Ground is good too. What could be wrong?
瀏覽: 3689   回覆: 1
Netro Spark
Juan Manuel Fernández de Sosa
更新時間 2024-06-22 20:41:47 UTC
En relación con mi pregunta anterior ya he visto que poniendo el riego nocturno a las 23:30 se acepta, pero si se pone a las 23:59 sale el error. Por lo tanto anulen mi anterior pregunta, aunque me resulta algo extraño que no permita 23:59 siendo el mismo día.
Saludos.
瀏覽: 3597   回覆: 1
Netro Spark
更新時間 2024-06-22 20:24:29 UTC
He instalado mi nuevo Netro Spark. En modo smart produce demasiados riegos en una determinada zona de forma muy constante, y con demasiado tiempo. No me parece nada lógico. Quiero dejar eliminado el modo smart y programar personalmente el riego. Consigo programar un riego de las cuatro zonas que utilizo en un determinado horario de la mañana, pero cuando voy a añadir un segundo riego diario por la noche me da un mensaje "ERROR: Program cannot cross a day".
¿Significa esto que solo puedo programar un riego al día? Muy extraño, mi anterior programador permitía tantos riegos diarios como quisiera simplemente indicando las horas.
Por favor, una solución, porque si solo se puede programar un riego al día no me soluciona nada este dispositivo.
Gracias.
瀏覽: 3617   回覆: 1
one zone not opening
BBurford88
更新時間 2024-06-03 16:54:39 UTC
Has anyone had only one zone not work properly? I've checked my voltages and everything seems to be normal but one of my 4 zones does not operate either with the schedule or manually running the zone. Any tips help cause i'm at a complete loss.
Thanks in advance
Boyce
瀏覽: 3591   回覆: 1
Pump shuts off after 5-10 mins
Vardhan Rajkumar
更新時間 2024-06-01 22:02:36 UTC
I just restarted my irrigation system after the winter.  I have tried to manually run a zone.  After watering for 5-10 mins the water turns off but the Netro timer still shows watering.
I am trying to determine whether the pump has turned off because the Netro "on" signal stopped or whether the thermal overload relay on the pump circuit caused it to shut off.
Is there a way I can check which it may be?
Vardhan
瀏覽: 3649   回覆: 1
Multiple zones running on Netro Sprite sprinkler system
gosparty01
更新時間 2024-05-27 17:47:14 UTC
I have three zones that are running at the same time with low water pressure to all three. This is a new problem. Any ideas on hat might be causing it?
So far I've tried replacing one solenoid, that did not work. I switched the zones in the control box for one of the three zones but the same result when I activated the switched zone.
I also tried disconnecting one of the zones, and when I triggered it it did not run. But when I triggered one of the zones I left connected, it did run with low water pressure
瀏覽: 3706   回覆: 1
Zone Won't Disable
更新時間 2024-05-25 20:49:25 UTC
I have tried to disable this zone in settings, but it will not disable.  If anyone knows a solutions please let me know.
瀏覽: 3692   回覆: 1
Pixie Z1 Battery Drain
Passawit Kaovilai
更新時間 2024-05-12 03:01:25 UTC
One of my Pixie Z1 is after months of use is having abnormal battery drain where a 100% battery to dead within 3 days. Is this something warranty would cover?
I've replaced 3 sets of AA batteries now within a week or so.
瀏覽: 3720   回覆: 1
Schedule issue
Barbara Williams
更新時間 2024-05-03 17:43:01 UTC
I have 3 zones. We have had system running for several weeks early in the morning. Yesterday I checked history & found all 3 zones had instead of a green checkmark icon, an orange wifi with red x icon (see photo below). I was able to try "run now", and only zone 1 worked.
I ended up deleting ALL schedules & did a one time water on zones 2 & 3 & they worked. I made a new schedule for all 3 zones, and this morning i got the orange wifi icon on zone 1, & zones 2 & 3 ran just fine.
Any ideas?   TIA!
瀏覽: 3907   回覆: 1
