Remote reboot of whisperer
更新時間 2025-08-17 14:48:38 UTC
Is there a way to remotely reboot a whisperer sensor?
I am on vacation adn one of the sensors is showing up weird values in all the parameters.
瀏覽: 828   回覆: 1
Whisper not showing any moisture reading at all
更新時間 2025-08-12 02:45:00 UTC
Why is Whisperer not showing any moisture reading at all? after working fine for days, it just stops sending moisture info
瀏覽: 850   回覆: 1
Problem: Spark 8 controller stuck on "in communication"
Stefano F
更新時間 2025-08-10 07:01:41 UTC
Hi everyone,
I'm experiencing a serious issue with my Netro Spark 8 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
Despite these attempts, the problem persists. I also tested the solenoids with a multimeter, and they’re working correctly. If I activate the valves directly from the controller, they respond as expected—so it’s clearly not a hardware issue.
I should also mention that I previously had the same problem with two Sprite6 controllers. That’s why I switched to the Spark 8, hoping it would solve the issue. Unfortunately, it hasn’t.
To make matters worse, scheduled programs aren’t working either.
This is an urgent situation because my plants are currently without water. I’d really appreciate any help or suggestions to resolve this.
Thanks in advance,
Stefano
瀏覽: 432   回覆: 2
Daniele Fuccio
更新時間 2025-07-18 17:17:18 UTC
What could the issue be?
Thank you in advance
瀏覽: 1088   回覆: 1
Ricardo Ribeiro
更新時間 2025-07-12 13:05:48 UTC
Can you help?
瀏覽: 1098   回覆: 1
Umidità terreno
Alessandro Zannini
更新時間 2025-07-03 19:20:15 UTC
瀏覽: 1925   回覆: 1
Whisperer 1 Dead
更新時間 2025-07-03 15:13:13 UTC
瀏覽: 1594   回覆: 0
francescomaggi
更新時間 2025-06-16 21:04:10 UTC
瀏覽: 1290   回覆: 3
Error valve
becerril
更新時間 2025-06-10 19:45:14 UTC
瀏覽: 1459   回覆: 1
Refurbished netro controller
drylake
更新時間 2025-05-23 23:37:47 UTC
瀏覽: 2059   回覆: 1
Whisperer 2 temperature?
Brett Rabe
更新時間 2025-05-09 19:07:46 UTC
Thoughts?
瀏覽: 2409   回覆: 1
Andrea DS
更新時間 2025-04-22 12:33:21 UTC
瀏覽: 2348   回覆: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
更新時間 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
瀏覽: 2977   回覆: 1
Sprite went offline
dkoford@gmail.com
更新時間 2024-12-18 02:30:29 UTC
瀏覽: 3244   回覆: 1
Solenoid does not switch off
Nath Moyes
更新時間 2024-11-15 00:49:20 UTC
Nath
瀏覽: 3280   回覆: 1
Netro Spark valve testing
Peter Strohmayer
更新時間 2024-11-14 13:49:20 UTC
Peter
瀏覽: 3237   回覆: 1
Zone won't shut off.
shoo.shoo
更新時間 2024-11-10 05:55:43 UTC
瀏覽: 3266   回覆: 1
BrettEnyart
更新時間 2024-10-13 18:02:06 UTC
瀏覽: 3431   回覆: 1
12330barryknoll
更新時間 2024-10-10 01:51:03 UTC
瀏覽: 3437   回覆: 1
cjulian
更新時間 2024-10-05 18:05:09 UTC
瀏覽: 3441   回覆: 1
