Pixie Leaks
Rich Keith
更新時間 2020-04-19 17:18:48 UTC
瀏覽: 4749   回覆: 1
Max V
更新時間 2020-04-17 09:46:19 UTC
瀏覽: 4838   回覆: 1
Luca Manfrin
更新時間 2020-04-10 11:43:03 UTC
瀏覽: 5224   回覆: 2
Seb Cruzer
更新時間 2020-04-07 15:03:43 UTC
hello,
Please help!
瀏覽: 5081   回覆: 2
Luca Manfrin
更新時間 2020-04-07 09:33:03 UTC
瀏覽: 4758   回覆: 1
Host mode
Luca Manfrin
更新時間 2020-04-06 17:55:38 UTC
What is host mode?
瀏覽: 4997   回覆: 1
Casey S
更新時間 2020-04-05 19:41:30 UTC
瀏覽: 5010   回覆: 1
Yohan
更新時間 2020-03-22 00:49:00 UTC
瀏覽: 4859   回覆: 1
stefano banfi gaslini
更新時間 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
瀏覽: 4772   回覆: 1
Whisperer issue
Saul Perez
更新時間 2020-03-15 19:07:50 UTC
瀏覽: 4694   回覆: 1
Benedetto
更新時間 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
瀏覽: 4830   回覆: 1
Watering stops after 5 mins
D String
更新時間 2020-02-29 17:22:32 UTC
瀏覽: 4652   回覆: 1
Watering stop problem
lekter
更新時間 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
瀏覽: 4881   回覆: 0
Light still blinking fast after pressing RST button
marcplesh
更新時間 2020-01-20 23:27:20 UTC
Any suggestions? Thanks. Already unplugged from outlet for about 10 seconds and plugged back in.
瀏覽: 4837   回覆: 1
setting up sprite location service on cellphone not on ... but it is
Michael Pakalolo
更新時間 2020-01-12 16:51:03 UTC
hi there, my sprite was working fine for 3 month , now i had no internet for 24 hours and sprite did not connect to the internet anymore . I restarted the router and then the sprite and still no internet connection but my router is fine and i have internet. So i reset the sprite and now it says i need to allow location service on my phone but it is on!!! it will not allow me to setup the sprite and i don't know what to do?
瀏覽: 4878   回覆: 1
Tim Foster
更新時間 2019-12-05 17:56:44 UTC
瀏覽: 5154   回覆: 1
Brian Hobbs
更新時間 2019-10-15 01:58:49 UTC
瀏覽: 4973   回覆: 1
Nguyễn Vinh
更新時間 2019-09-30 06:46:55 UTC
瀏覽: 5227   回覆: 2
更新時間 2019-09-17 12:12:15 UTC
瀏覽: 5278   回覆: 1
Power Transformer
DeanH
更新時間 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
瀏覽: 6200   回覆: 3
