Can't reconnect wifi
Yuriy Andamasov
更新時間 2023-07-05 21:14:40 UTC
sprite-6 went offline
never pass step 5
worked just fine almost year
瀏覽: 4052   回覆: 1
Battery LED Blinking
E B
更新時間 2023-06-29 15:33:28 UTC
瀏覽: 4354   回覆: 1
Connection issue
Federica Musmanno
更新時間 2023-06-27 12:16:35 UTC
瀏覽: 3871   回覆: 1
Massimo Oldrini
更新時間 2023-06-20 07:57:16 UTC
Buongiorno,
L’apparato va sostituito?
瀏覽: 3895   回覆: 2
Whisperer sensor
更新時間 2023-06-10 17:39:10 UTC
瀏覽: 4199   回覆: 1
Netro sprite chpset.
Eduardo Pariente
更新時間 2023-06-09 18:15:34 UTC
Hello everyone.
Thanks you.
瀏覽: 3794   回覆: 0
Eduardo Pariente
更新時間 2023-06-09 18:15:24 UTC
Hello everyone.
Thanks you.
瀏覽: 3929   回覆: 1
Corinne Cleary
更新時間 2023-06-01 00:55:20 UTC
Please help.
瀏覽: 3768   回覆: 1
Arturo Camin
更新時間 2023-05-30 09:17:10 UTC
瀏覽: 3958   回覆: 1
Network Error with code: 3405
Stefan W.
更新時間 2023-05-27 20:05:45 UTC
Hi everyone. When I try to add another user in the app, I get the message „Network Error with code: 3405“
Any solution for this?
瀏覽: 3937   回覆: 1
One channel is always on
Stefan W.
更新時間 2023-05-27 19:58:05 UTC
Hi everyone,
I have a 6-channel Sprite with 6 hunter valves. 5 channels work perfectly, one seems to be always on. I tried a brand new valve, a reset of the Sprite, unplugged it from power, changed the wiring but nothing helped. Any ideas?
Cheers, Stefan
瀏覽: 3928   回覆: 3
Zones
Lea Schneider
更新時間 2023-05-25 23:29:01 UTC
My zones 5-12 won’t work but my zones 1-4 are working fine .    Any ideas what to do ?
瀏覽: 3845   回覆: 1
Watering problem
Marco Nicosia
更新時間 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
瀏覽: 3690   回覆: 1
更新時間 2023-05-14 12:23:35 UTC
Kirk
瀏覽: 4102   回覆: 1
No light
Gabriele Gualtieri
更新時間 2023-05-10 17:13:50 UTC
瀏覽: 3889   回覆: 1
Katie Woggins
更新時間 2023-04-24 18:40:07 UTC
瀏覽: 3737   回覆: 1
Master error “open circuit”
Neil Lucey
更新時間 2023-04-24 14:09:12 UTC
Neil
瀏覽: 3765   回覆: 1
Pixie keeps disconnecting
Sang Peiris
更新時間 2023-04-18 12:44:42 UTC
瀏覽: 3913   回覆: 1
No 24V output?
Bigolin Davide
更新時間 2023-03-26 16:15:24 UTC
What can I do?
瀏覽: 3722   回覆: 1
Carlo Drago
更新時間 2023-03-18 18:55:41 UTC
Waiting your kind reply
Carlo
瀏覽: 4003   回覆: 1
