Keep Online
bechard
更新時間 2021-07-24 11:09:25 UTC
瀏覽: 3900   回覆: 0
gbs-122
更新時間 2021-07-11 10:22:07 UTC
瀏覽: 4261   回覆: 2
Zero Readings
Billy Wood
更新時間 2021-06-26 00:28:05 UTC
瀏覽: 4334   回覆: 1
Mike Willet
更新時間 2021-06-24 20:47:47 UTC
3 for backyard
3 for front yard
1 for drip irrigation in back
瀏覽: 4176   回覆: 1
Reset whisper sensor
Yuriy Andamasov
更新時間 2021-06-24 18:06:20 UTC
Like hard reset
Not like that
瀏覽: 4419   回覆: 1
Whisperer Bad Readings
Billy Wood
更新時間 2021-06-13 19:42:18 UTC
瀏覽: 4337   回覆: 1
Low pressure on pixie
Martin Le Ménach
更新時間 2021-06-08 07:20:16 UTC
瀏覽: 4277   回覆: 1
Wi-Fi connectivity
saketshah
更新時間 2021-05-31 21:20:22 UTC
Appreciate your help.
瀏覽: 4325   回覆: 1
Wisperer not working
Andrea Paparotti
更新時間 2021-05-31 14:42:20 UTC
瀏覽: 4699   回覆: 2
Netro Pixie Timer
claudinne
更新時間 2021-05-20 17:09:36 UTC
瀏覽: 4389   回覆: 1
Whisperer shows different data on hourly vs daily humidity
Panos Charalambopoulos
更新時間 2021-05-03 07:40:53 UTC
My whisperer shows 99% humidity stuck in one zone in the hourly and dashboard views. The weekly daily monthly views all show progressively dropping humidity. Which one is correct and how do I possibly reset this ? Also do my watering schedules get affected by the hourly or the daily humidity ?  My other whisperer shows consistent data between hourly and other views.
瀏覽: 4259   回覆: 1
Whisper controlled zone down to 11%
Simon Clark
更新時間 2021-04-28 20:59:55 UTC
I have a whisper connected to a zone that I have defined as new plant as it’s young vegetable plants. It says it will run every day for 9 minutes.
However it’s not come on for the last week and when I checked today the moisture was down to 11%!
Why hasn’t the zone been running?
I can’t rely on your product if it doesn’t do the basics that keeps my plants alive.
瀏覽: 4603   回覆: 1
Weather data
Vardhan Rajkumar
更新時間 2021-04-21 18:03:34 UTC
Vardhan
瀏覽: 4636   回覆: 1
Michael Sheahan
更新時間 2021-04-19 21:19:54 UTC
瀏覽: 4284   回覆: 1
Tony Pellegrino
更新時間 2021-04-13 19:14:36 UTC
瀏覽: 4332   回覆: 1
jjmengibar
更新時間 2021-04-05 18:19:11 UTC
瀏覽: 4617   回覆: 1
Many inexplicable Manual runs
更新時間 2021-04-03 11:37:15 UTC
Hello everyone ,
瀏覽: 4365   回覆: 1
Wild Swings In Moisture %
Mike Biondo
更新時間 2021-03-27 22:08:54 UTC
I am seeing 20%+ increases in soil moisture when there is no rain and I am not watering and also 20%+ reductions in moisture directly after watering which seems counterintuitive. Is this normal? Can anyone explain what is going on to me? Thank you!
Mike
瀏覽: 4565   回覆: 1
AMC
更新時間 2021-02-18 13:04:06 UTC
hello,
¿How Can I solve this issue?
APP version 2.5.3
瀏覽: 4495   回覆: 3
Master valve timing
joeac
更新時間 2020-12-04 05:38:31 UTC
Product: Sprite
Joe
瀏覽: 4515   回覆: 1
