Dennis N
更新時間 2019-05-18 17:52:30 UTC
瀏覽: 4990   回覆: 1
David Claridge
更新時間 2019-05-18 13:21:53 UTC
瀏覽: 5068   回覆: 1
John Locke
更新時間 2019-05-05 14:16:12 UTC
瀏覽: 5314   回覆: 1
John Mac
更新時間 2019-04-22 23:42:30 UTC
瀏覽: 4996   回覆: 1
Nathan Anderson
更新時間 2019-02-13 03:53:31 UTC
瀏覽: 5520   回覆: 1
Tim Cox
更新時間 2019-02-02 01:35:59 UTC
瀏覽: 5566   回覆: 3
Sangjin Lee
更新時間 2018-12-15 18:56:48 UTC
Thanks in advance!
瀏覽: 8717   回覆: 1
Water pump shutting off
Ryan Cochran
更新時間 2018-11-26 02:32:24 UTC
瀏覽: 5492   回覆: 1
Controller
Phil Samson
更新時間 2018-10-12 18:41:33 UTC
My controller shows that it’s online but the app is saying I’m offline. How do I correct this?
瀏覽: 5164   回覆: 0
Sprite not running zones after power outage
Rob Platko
更新時間 2018-09-08 17:28:57 UTC
Hi, my Sprite does not run any program on any zone following a power outage.  The zones are scheduled, I can see them in the calendar, but they don’t run.  Anyone seen this problem?
瀏覽: 5240   回覆: 0
