Irrigation time striketrough
Luca Manfrin
更新时间 2020-04-07 12:34:22 UTC
thank you
浏览: 7962   回复: 1
Seb Cruzer
更新时间 2020-04-07 15:03:43 UTC
hello,
Please help!
浏览: 9670   回复: 2
Power adapter - eu
David B.
更新时间 2020-04-08 13:43:20 UTC
I have a netro sprite with an original power adapter.
How ca i connet this to my 220/230 Volt energynet in Austria pls?
A normal Adapter will not work since i have to tansform volt and ampere to 800ma and 110volt as far as i could find informations.
Kind regards david
浏览: 9722   回复: 1
Resetting Netro Whisperer
Patrick
更新时间 2020-04-09 19:34:52 UTC
浏览: 9434   回复: 1
Incorrect weather conditions
Andrea Merito
更新时间 2020-04-09 20:33:11 UTC
as the state / province is changed because Madrid is specified instead of Catania, consequently the weather is incorrect.
浏览: 9405   回复: 1
Luca Manfrin
更新时间 2020-04-10 11:43:03 UTC
浏览: 9747   回复: 2
Netro app on google home
Danilo
更新时间 2020-04-11 10:07:58 UTC
Thanks for your support.
浏览: 7726   回复: 1
Brett Lilly
更新时间 2020-04-13 18:42:28 UTC
浏览: 7915   回复: 1
Faucet Connector Broke
Larry Griggers
更新时间 2020-04-14 18:49:27 UTC
I was having difficulty getting a leakproof seal when attaching my Smart Hose Faucet Timer (Pixie-1) to my new faucet. I finally was able to tighten it tight enough not to leak, but after a week, it broke and popped off. It is probably under warranty, but is there somewhere I can buy a new connector and repair it myself?
浏览: 9063   回复: 1
Luca Manfrin
更新时间 2020-04-16 07:47:25 UTC
Thank you for your support
浏览: 8080   回复: 2
Luca Manfrin
更新时间 2020-04-16 10:23:31 UTC
thank you
浏览: 8085   回复: 1
Range of whisperer
Fraco
更新时间 2020-04-16 19:35:32 UTC
Is there a maximum distance I can place the whisperer(s) in the garden. Largest distance it should cover is approx. 30 mtrs.
The sprite probably will be placed inside.
浏览: 10519   回复: 1
Which Alexa app?
jbart65
更新时间 2020-04-16 20:00:55 UTC
Jeffry
浏览: 7977   回复: 1
Max V
更新时间 2020-04-17 09:46:19 UTC
浏览: 9326   回复: 1
Keep Connected option
jbart65
更新时间 2020-04-17 17:38:10 UTC
The particulars:
浏览: 7838   回复: 1
Forecast vs Expectation
Arvind Ramanadham
更新时间 2020-04-17 18:25:49 UTC
浏览: 8388   回复: 1
Mixed Plant Zone
Rich Keith
更新时间 2020-04-18 23:36:39 UTC
浏览: 7593   回复: 1
Netro-Community using App
Lou Infeld
更新时间 2020-04-19 13:46:12 UTC
浏览: 8842   回复: 1
Pixie Leaks
Rich Keith
更新时间 2020-04-19 17:18:48 UTC
浏览: 9118   回复: 1
How protect Netro Sprite
Stefano Carucci
更新时间 2020-04-21 09:14:57 UTC
I need to install the Netro Sprite in a tool shed covered by tiles and closed only on three sides that I have in the garden (L 2mt, W 1.5mt, H 1.8mt).
I would like to know if, to protect it from humidity, dust and insects, I can install it in a box like this:
https://www.amazon.com/Fielect-Transparent-Switchboard-Distribution-115x90x50mm/dp/B07ZR2HN5B/ref=sr_1_17?dchild=1&keywords=transparent%2BDistribution%2Bbox&qid=1587458726&rnid=2941120011&s=hi&sr=1-17&th=1
and if this box can decrease the reception of the wifi signal.
浏览: 9994   回复: 1
