Watering stop problem
lekter
更新时间 2020-02-14 14:43:36 UTC
When I start watering to give it a try. Everything's going well. But when I want to stop watering it's impossible. I have to turn off the power so that netro stops the watering.
WeatherPro is the problem ?
For information, I have an electrovanne rainbird.
Arnaud
浏览: 9272   回复: 0
new dripping system using Pixie and Whisperer
Markus Matula
更新时间 2020-02-20 08:52:39 UTC
I am in the process of designing my dripping system for my beach house in FL. I am thinking about using 2 Pixies and several Whisperers. I have several questions: 1) What happens when the WIFI is down? Does Pixie turn watering off/on on its own? 2) Does Pixie skip a watering cycle when raining? 3) Are the Whisperers connected to the Pixie and App in that the humidity information guides the amount and frequency of watering? 4) What is the recommended soil humidity for new planted palm trees? Thanks, Markus
浏览: 8615   回复: 1
App Crashes on adding product
Tarudro
更新时间 2020-02-24 20:24:10 UTC
I just received my Pixie and Whisperer and wanted to set them up using my iPhone.
Therefore I launch the app and go to "Add Product", select the Pixie and then I'm promted to enter my location and a name for the timer.
When I click on "next" the app crashes and returns to the home screen. 100% reproducible. I tried to enter different adress and name, but couldn't make it work. Crashes every time.
Reinstall also didn't solve the problem.
Netro App: 2.4.0
iPhone 11 Pro
iOS 13.3.1
German (also tried English)
Let me know, if you need anything else to reproduce/solve this issue or if there is something that I could do to prevent it.
So far, I couldn't find anything in the forum here.
BR Lukas
PS. I just tried also on my iPad Air 2 - same crash.
浏览: 15809   回复: 4
Claude Bedarride
更新时间 2020-02-29 14:28:34 UTC
浏览: 7514   回复: 1
Watering stops after 5 mins
D String
更新时间 2020-02-29 17:22:32 UTC
浏览: 8819   回复: 1
Distance between controller and solenoid valves
Steve Cary
更新时间 2020-03-01 14:42:55 UTC
My controller will be about 20 meters from the solenoids.  What size cable do I need to make this work? Thankyou!!
浏览: 8961   回复: 1
Carlo D'Ippolito
更新时间 2020-03-01 14:55:14 UTC
Waiting for your feedback.
Kind regards
浏览: 8765   回复: 1
Is it working correctly? 0v test multimeter
yodiego
更新时间 2020-03-07 12:14:59 UTC
Hi good morning,
I’m making the first installation and I see the valves don’t open when I tested it, so I test the connections with a multi-meter and sometimes it gives 24v and sometimes 0.
The last 10 tries it gives 0. I changed the cables and I now I test directly the controller connections and keep giving me 0.
I’m using the manual watering to make the tests.
Thank you for your help.
浏览: 9112   回复: 1
alexa & pixie
stefano banfi gaslini
更新时间 2020-03-11 14:30:37 UTC
hi,
TNKS
best regards
stefano
浏览: 7806   回复: 1
Benedetto
更新时间 2020-03-11 14:44:38 UTC
Thanks for the support
Br
BG
浏览: 9337   回复: 1
Sprinkler is on during rain
Wahid Ameni
更新时间 2020-03-14 00:12:38 UTC
浏览: 7802   回复: 1
Delivering term please
yodiego
更新时间 2020-03-14 18:08:21 UTC
浏览: 7453   回复: 1
Whisperer issue
Saul Perez
更新时间 2020-03-15 19:07:50 UTC
浏览: 8976   回复: 1
Javier Palomino
更新时间 2020-03-18 02:11:35 UTC
浏览: 7423   回复: 1
更新时间 2020-03-18 15:16:20 UTC
hi,
it was particularly dry.
indicates that it is 98% wet.
what is wrong?
tnks
best regards
stefano
浏览: 9245   回复: 1
Instalación wifi
Eduardo Pariente
更新时间 2020-03-20 16:15:47 UTC
Good afternoon.
 I have problems because I don't recognize the wifi.  I'll explain. First I connect by wifi to netro and it does not give me any problems.  But when I go back to the next screen to connect the mobile to the wifi and the wifi from home no longer appears. He's gone. And I can't continue with the installation.
浏览: 9088   回复: 1
Yohan
更新时间 2020-03-22 00:49:00 UTC
浏览: 9447   回复: 1
Smart scheduling problem
更新时间 2020-03-23 19:15:51 UTC
This is my set up.
1) why this happened?
浏览: 8367   回复: 1
Giacomo
更新时间 2020-03-24 14:44:34 UTC
Thanks in advance
浏览: 8676   回复: 1
J H
更新时间 2020-03-24 21:16:47 UTC
浏览: 7485   回复: 1
