Windows 10 APP or web page
Emanuel Di Giusto
更新时间 2019-09-06 19:46:57 UTC
浏览: 8046   回复: 1
Tony D.
更新时间 2019-09-09 12:57:04 UTC
浏览: 8930   回复: 1
Feature request
Tony D.
更新时间 2019-09-12 20:32:30 UTC
Tony
浏览: 8554   回复: 1
更新时间 2019-09-17 12:12:15 UTC
浏览: 9924   回复: 1
Unit measurements
Homestead One
更新时间 2019-09-17 20:29:09 UTC
浏览: 7995   回复: 1
Schedule setup
Rich Christenson
更新时间 2019-09-21 14:51:31 UTC
浏览: 8040   回复: 1
Whisperer seems wrong
Tim Foster
更新时间 2019-09-22 15:02:12 UTC
I only got my system delivered yesterday, so this could be something that I doing wrong, I have one whisperer in the back garden and one in the front. I live in Merida Yucatan and so it's hot all the time. The whisperer in the back is in direct sunlight most of the day yet it's reporting the temperature as 24. The one in the front is shaded by the house yet that is reporting 33. Both seem to be reporting incorrect moisture levels in both the topsoil and subsoil. Yucatán drains through stone to underground water sources so I would expect both topsoil and subsoil to be showing very arid.
Can anyone advise?
浏览: 9557   回复: 1
Tony D.
更新时间 2019-09-24 21:08:17 UTC
Hello everybody,
浏览: 8440   回复: 1
Ip address
Kris Y
更新时间 2019-09-25 20:13:08 UTC
浏览: 8208   回复: 1
Solid white light after install - HELP
Carlos Oliveira
更新时间 2019-09-25 20:29:08 UTC
I have just replaced a Rain bird image 6 by the Netro Sprite and I am using it's power supply.
The problem is that once I connect it after first install it gets to solid white light. I press reset shortly or even for 8 seconds but nothing changes.
Can someone help me ?
浏览: 9734   回复: 1
Cold winter season and whisperer ?
Yves Desrosiers
更新时间 2019-09-26 11:12:56 UTC
We have to take back inside our home the whisperer when the cold season is back I guess ? At what  exterior tempeture we should do this ?
浏览: 11386   回复: 3
hanz.blatt@gmail.com
更新时间 2019-09-29 13:59:02 UTC
浏览: 14932   回复: 2
Nguyễn Vinh
更新时间 2019-09-30 06:46:55 UTC
浏览: 9914   回复: 2
sqwu
更新时间 2019-09-30 13:51:09 UTC
浏览: 8426   回复: 1
Installation Direct to pump
Tim Foster
更新时间 2019-10-03 11:23:32 UTC
I have the following:
浏览: 10026   回复: 2
Weird watering plan
Manuel Roca
更新时间 2019-10-12 11:34:00 UTC
浏览: 7918   回复: 1
Brian Hobbs
更新时间 2019-10-15 01:58:49 UTC
浏览: 9413   回复: 1
Sangjin Lee
更新时间 2019-10-17 03:41:11 UTC
浏览: 8199   回复: 1
What about blowout?
Burghardi
更新时间 2019-10-18 02:06:15 UTC
Why doesn’t this one?
浏览: 8211   回复: 2
Riego netro para tepes
Manuel C
更新时间 2019-10-23 09:36:27 UTC
Hola,
浏览: 12416   回复: 1
