Removing plant sensor
Alessia
更新时间 2019-08-14 20:41:19 UTC
Hello, how can i remove the plant sensor which i added for error?
浏览: 9718   回复: 1
Zones run at the same time
Rich Christenson
更新时间 2019-08-15 11:05:09 UTC
浏览: 10217   回复: 3
Whisperers firmware update
更新时间 2019-08-15 16:25:53 UTC
When is it going to be released?
浏览: 9116   回复: 0
更新时间 2019-08-16 02:54:33 UTC
浏览: 8682   回复: 1
Alexa skill
Tony D.
更新时间 2019-08-16 23:42:33 UTC
What do I need to search for?
浏览: 8488   回复: 1
Rainfall correction
cjmulk2
更新时间 2019-08-17 03:15:16 UTC
Feature request: On the discover screen, please allow rainfall correction further back than yesterday and allow setting the correct rainfall amount to zero. (Lowest it goes currently is 0.1).
浏览: 9608   回复: 1
Feature Request: API
cjmulk2
更新时间 2019-08-17 03:18:34 UTC
浏览: 8904   回复: 3
Drain
Moe
更新时间 2019-08-17 23:31:13 UTC
浏览: 8352   回复: 1
Why water twice a day?
Ron White
更新时间 2019-08-19 19:05:12 UTC
浏览: 8129   回复: 2
Internet connection problems
danadcock
更新时间 2019-08-20 14:07:11 UTC
I have had a lot of trouble with losing netro's connection with internet. My old router failed so I replaced it with an expensive mesh wifi system which provides wonderful service to everything I have tried to connect except my Netro! I have now discovered that it will not work with anything but 2.4 GHz wifi. The new wifi does not provide 2.4 connection. Is there a workaround for this? Or do I have to throw out my new state-of-the-art $400 5 GHz wifi to get my somewhat obsolete $100 Netro to work?
浏览: 9976   回复: 2
Smart watering once a week?
Andrea D.
更新时间 2019-08-22 05:51:16 UTC
Hello there,
I'm new to netro and I tried to setup smart watering but the data I provided it will do it just once a week.
How is it possible? Is it safe to water just once a week?
浏览: 7925   回复: 1
Weather Provider
Martin Müller-Zantop
更新时间 2019-08-22 10:57:44 UTC
Can you please explain to me the big difference of the next watering days using different weather providers? As you can see in my print screens the data of temperature and humidity are nearly the same. With one provider next watering cycle will be in 2 days and with another in 11 days.
Thank you for your comments
Martin
浏览: 8981   回复: 2
Yellow triangle with ! Inside
Michael Pakalolo
更新时间 2019-08-24 16:15:54 UTC
What does the yellow triangle with the ! mean next to the schedule
浏览: 9626   回复: 1
How does a whisper sensor work with a drip system?
L F
更新时间 2019-08-25 23:46:33 UTC
I have a couple whisper sensors monitoring my lawn and drip system.   I understand how they can monitor the soil in my lawn but I’m wonder how the whisper works on my drip system as it doesn’t see the moisture that’s added to the soil(the emitter isolates the water to the plant) or the rate the plants use it like the one in the lawn does.  I’m assuming it’s just estimating like the Netro would on it’s own.  Is there much value to using a whisper on a drip zone?
浏览: 8568   回复: 1
watering sequence
Gérard GALBOIS
更新时间 2019-08-26 18:23:46 UTC
It is unfortunatly not possible to change  in which ordre the watering will act.
for exemple I need to water zone 5 after zone 7 because zone 7 is at a higher level than the electro valve and remaining water pressure, after watering is stopped,  is to strong and prevents the valve to close . by watering supplemantary  zone 5 which is lower the pressure diminishes ans the valve of zone 7 closes..
浏览: 8080   回复: 1
System went basqerk?
Ron White
更新时间 2019-08-27 01:21:18 UTC
浏览: 8417   回复: 2
Power Transformer
DeanH
更新时间 2019-09-04 02:31:34 UTC
I have my controller in my garage here in the desert.  The transformer seems very hot to the touch.  Is this a problem??
浏览: 11228   回复: 3
New Whisper not reporting
更新时间 2019-09-04 17:11:14 UTC
I recently ordered a second whisper and installed it the same way as the first one I received (which is still working fine)  It connects just fine and I can even change the color of the LED for a while.  But it reported only once to the app and that was it.  I have tried reconnecting it to WiFi, I even deleted it in the app and reinstalled it with no success.  After the initial connection it seems to just stop working.
浏览: 10226   回复: 1
Ron White
更新时间 2019-09-04 16:44:17 UTC
浏览: 8427   回复: 1
Manual run time screen
Rich Christenson
更新时间 2019-09-06 10:25:49 UTC
浏览: 8570   回复: 1
