Daylight savings
Craig Neidle
更新时间 2019-11-13 18:34:27 UTC
Haow can i change this?
浏览: 8026   回复: 1
Manuel Roca
更新时间 2019-11-22 17:20:29 UTC
This is an easy question
浏览: 7956   回复: 2
Black Friday
John Mayer
更新时间 2019-11-22 10:40:22 UTC
Hello Netro, will you have a black Friday offer?
浏览: 15375   回复: 1
Smart zone enabled
Steve Kalani
更新时间 2019-11-25 18:36:19 UTC
浏览: 7285   回复: 1
Works in Uruguay?
Sebastian Diaz
更新时间 2019-11-26 20:39:14 UTC
Hello I bougth my first netro sprite but i can not find the country Uruguay and i the smart not work correctly, how i can resolve this issue?
浏览: 9405   回复: 1
Whisperer settings
Manuel Roca
更新时间 2019-11-30 23:47:29 UTC
I’m wondering how many whisperer units I need to have if I my garden has 8 zones. Do I have to get 1 per zone?
浏览: 9308   回复: 1
Wire Gauge
Brian Paternostro Paternostro
更新时间 2019-12-02 15:14:19 UTC
Replacing old Toro system,  all my wires from the zones are too thick to place into the system.  Do you have a wire gauge I can slim down the wires to make it work?
浏览: 9418   回复: 1
Product request: leak detector
Joshua Berk
更新时间 2019-12-03 05:45:42 UTC
I would love to see a leak detector we could install onto the water lines that could communicate the amount of water used and detect leaks. Like the one Rachio offers.
浏览: 9160   回复: 1
Can't add new managers
Tim Foster
更新时间 2019-12-03 20:00:25 UTC
浏览: 7740   回复: 1
Tim Foster
更新时间 2019-12-05 17:56:44 UTC
浏览: 9267   回复: 1
Raining but still watering
Liaqat Khan
更新时间 2019-12-08 00:23:51 UTC
浏览: 7260   回复: 1
Watering
Tim Foster
更新时间 2019-12-14 13:23:21 UTC
I have my first period of rain coming up, so the smart schedule isn't planning on watering until Christmas Eve. Since getting the sensors working properly I've been very happy with the smart watering, but the rain predictions here tend to be a bit sketchy. As my system is saying it won't water because there is rain expected, does it automatically adjust itself and water if the predicted rain doesn't arrive?
Also, I have it set to not water if expected rain is 5mm. What is the difference in this context between expectation and forecast?
浏览: 7810   回复: 1
Soil Types
Tim Foster
更新时间 2019-12-14 13:28:44 UTC
The app asks me to define my soil type and gives me a small list to choose from. I'm no gardening expert by any means and so I'm not really sure I've got this right. I selected the most draining type based on nothing more that guesswork really. We're in Yucatán, México so the entire area is limestone rock, but this website (https://sites.google.com/site/soilsoftheyucatanpeninsula/soil-types) gives more detail about the soil types in Yucatán. All this has done though is confuse me more.
Is there any reliable way that I can determine my soil type in Netro? The website says it's likely to be one (or a combination) of Gleysols, Histosols, Vertisols, Solonchaks, Leptosols, and Cambisols
浏览: 7661   回复: 1
setting up sprite location service on cellphone not on ... but it is
Michael Pakalolo
更新时间 2020-01-12 16:51:03 UTC
hi there, my sprite was working fine for 3 month , now i had no internet for 24 hours and sprite did not connect to the internet anymore . I restarted the router and then the sprite and still no internet connection but my router is fine and i have internet. So i reset the sprite and now it says i need to allow location service on my phone but it is on!!! it will not allow me to setup the sprite and i don't know what to do?
浏览: 9189   回复: 1
Whisperer does not save through weeks and months
更新时间 2020-01-16 07:05:52 UTC
I have got a whisperer sensor since 6 months. It gives me each day the expected figures (temp, humidity, ...) but I have got no figures in the week and month view. It looks like the figures are not kept along days, weeks and month.
Please advice,
Christophe
浏览: 9264   回复: 1
all zone at the same time
Sebastian Diaz
更新时间 2020-01-17 15:58:03 UTC
hello, i have a netro Sprite and work on 3 zone, has con figúrate one at time, its posible configure to work with all zone at same times?
浏览: 9236   回复: 1
Light still blinking fast after pressing RST button
marcplesh
更新时间 2020-01-20 23:27:20 UTC
Any suggestions? Thanks. Already unplugged from outlet for about 10 seconds and plugged back in.
浏览: 8823   回复: 1
Robert Bayes
更新时间 2020-02-07 03:39:19 UTC
浏览: 6970   回复: 1
Master Valve
Simone Nolletti
更新时间 2020-02-07 09:53:47 UTC
Hello, is it possible to implement Netro with the master valve function? I have both well water and drinking water I would like to be able to choose which water to irrigate.
浏览: 9267   回复: 1
Changing ownership of home
Dario Sindicich
更新时间 2020-02-14 01:48:40 UTC
浏览: 9021   回复: 2
