Nomi zone e comandi alexa
Mirko Paganelli
更新时间 2020-05-05 06:26:19 UTC
浏览: 7762   回复: 1
Whisper wifi strength?
Weston Hull
更新时间 2020-05-05 17:29:53 UTC
Is there a way to see the wifi strength from the sensor.   From the phone I have good strength but from as far as the sensor it comes and goes for reporting.   Thanks!
浏览: 8795   回复: 0
How to delete Smart Schedule?
Matty Moe
更新时间 2020-05-06 01:35:06 UTC
浏览: 7542   回复: 1
Whisperer Changing Colors
Patrick
更新时间 2020-05-06 02:32:37 UTC
My Netro Whisperer sensor LED changed colors from blue to red on its own.  Is this normal?
浏览: 7586   回复: 1
Weston Hull
更新时间 2020-05-07 14:52:41 UTC
浏览: 7664   回复: 1
Discover your garden
更新时间 2020-05-07 16:16:29 UTC
Not only the last 12 months
浏览: 8001   回复: 1
Master valve
Sasha Obradovic
更新时间 2020-05-07 20:56:46 UTC
浏览: 8152   回复: 1
alnavasa
更新时间 2020-05-07 21:49:17 UTC
Feature request:
浏览: 8096   回复: 2
alnavasa
更新时间 2020-05-07 21:51:54 UTC
浏览: 8176   回复: 1
Kevin Tung
更新时间 2020-05-07 21:55:00 UTC
浏览: 7404   回复: 1
Andrea Merito
更新时间 2020-05-08 07:20:50 UTC
hello,
Andrea
浏览: 7728   回复: 1
Suited for exterio?
Joan Peiro
更新时间 2020-05-09 01:50:15 UTC
浏览: 7912   回复: 2
2 different water sources
Carlos Oliveira
更新时间 2020-05-09 14:51:27 UTC
I have the netro connected to one water source.
Now I am going to install a vertical garden with very low flow and I want the source of water to be a different one from the main source for the garden.
Is there a way I can connect it as an independent solenoide valve that doesn't need to have the master turned on ?
Carlos
浏览: 10647   回复: 1
Pixie Pending
Rich Keith
更新时间 2020-05-09 19:07:11 UTC
浏览: 7558   回复: 2
Chen Li
更新时间 2020-05-10 05:45:08 UTC
浏览: 7413   回复: 1
Unit system
Andrea DiPi
更新时间 2020-05-10 08:11:33 UTC
Gooooddddmoooooorning!
Here where we are!!! Torino - Cincinnati - Alice Sping - Skagen - Macao - ......
Is it possible set the app whit a unit as metric or imperial or...Mars?!? It is very boring that some parameters are in metric an other in sqft x ex.
浏览: 10001   回复: 1
Smart Watering Adjustment
Tarudro
更新时间 2020-05-11 20:56:22 UTC
Hi Guys,
Kind regards & stay healthy,
Lukas
浏览: 8202   回复: 2
where is the rst button
Jennml
更新时间 2020-05-12 18:00:51 UTC
浏览: 7530   回复: 1
Default rain settings
jbart65
更新时间 2020-05-12 21:31:24 UTC
浏览: 8047   回复: 1
hedges
Andrea Colombelli
更新时间 2020-05-14 19:45:52 UTC
浏览: 7594   回复: 1
