No 2.4GHz wifi
Carlos Oliveira
更新时间 2020-05-16 11:29:24 UTC
My netro has been working fine for the past many months.
Suddenly it stopped working and light blinks.
I try to configure the Wifi again and it states
I am sure my 2.4 GHz network is available there as I have 2 other devices 10 Cm away from the netro and are working fine at 2.4GHz
I can confirm that in my Orbi Router.
Any ideas ?
Carlos
浏览: 10855   回复: 1
Link to smart light
Noam Leshem
更新时间 2020-05-16 17:53:06 UTC
浏览: 8098   回复: 1
EASTBOBDAM D
更新时间 2020-05-17 13:18:19 UTC
Thanks in advance
浏览: 7502   回复: 1
Yves Desrosiers
更新时间 2020-05-17 18:31:27 UTC
Thanks for your help :)
浏览: 7979   回复: 1
Watering program
Maciej Karpinski
更新时间 2020-05-18 01:01:57 UTC
浏览: 9198   回复: 1
Pixie sync Sprite
Sebastian Diaz
更新时间 2020-05-19 02:50:59 UTC
Thanks you Sebastian
浏览: 8464   回复: 1
Kobus Marneweck
更新时间 2020-05-19 03:33:33 UTC
浏览: 7890   回复: 1
Best settings for garden
Alexandre Morin
更新时间 2020-05-20 11:01:20 UTC
thanks
浏览: 8714   回复: 2
Roman Prochazka
更新时间 2020-05-22 07:55:46 UTC
Many thanks for early answer
Best Regards
Roman
浏览: 8514   回复: 2
Wayne Richards
更新时间 2020-05-23 16:07:26 UTC
浏览: 7887   回复: 1
Rearranging zones?
Kurt H
更新时间 2020-05-23 19:17:20 UTC
浏览: 8413   回复: 1
Pressure compensated drip hose
Simon Clark
更新时间 2020-05-24 17:22:21 UTC
I use Netafin pressure compensated drip hose on all my beds and there doesn’t seem To be an irrigation type for that. Is it OK using the drip setting which seems to be for micro drippers.
浏览: 10703   回复: 0
Chris Graham
更新时间 2020-05-24 20:37:39 UTC
浏览: 8345   回复: 1
Is a full time wifi connection required for watering? Or any other unattended modes of failure?
Chris Graham
更新时间 2020-05-24 20:43:23 UTC
If wifi is disrupted will the controller continue to water acording to the most recently programmed schedules?
More generally are there any modes of failure (other than loss of power to the house) where the controller can unexpectedly halt watering?  It would be unacceptable to have one's garden die from lack of water if the system fails when one is away from home for a number of days.
浏览: 9694   回复: 1
更新时间 2020-05-25 16:08:09 UTC
浏览: 7814   回复: 1
Web interface
Emanuele Floridia
更新时间 2020-05-27 16:58:10 UTC
浏览: 8223   回复: 1
Delay between zones
Nicholas Lydakis
更新时间 2020-05-28 15:39:00 UTC
浏览: 7700   回复: 1
baijuviswam
更新时间 2020-05-28 18:56:02 UTC
浏览: 7419   回复: 1
Jesse For
更新时间 2020-05-29 08:33:36 UTC
浏览: 7454   回复: 1
Missing Whisperer
guags99
更新时间 2020-05-29 18:11:36 UTC
This season when I put my whisperer back out to monitor my garden bed I looked on the app and no longer saw that device. So I went through the process to re-add it to my network and my Netro account and I get an error message stating that that serial number is already registered.  Anyone have any thoughts on how I can de-register and re-register this device?  Thanks
浏览: 10290   回复: 1
