Smart watering issue?
Ananth
更新时间 2020-07-15 13:14:40 UTC
浏览: 8125   回复: 1
Netro Sprite dead after 27 months (3 months post-warranty)
Doug Burkott
更新时间 2020-07-17 11:26:34 UTC
Has anyone had an issue with their Sprite being inoperable shortly after the warranty ended?  I tested the power prongs with a voltmeter and the controller is getting electricity, but no lights are on.   It's 105 deg in Austin and no rain in sight.  I'm going out of town for 5 days, so I'm in trouble.  I'm going to have to go to Home Depot to get something off the shelf installed today before my trip.
Anyone with the same problem?  Has anyone been successful with a claim outside of the warranty period?
Update:  The Sprite went offline at the same time the LED light stopped working.  The watering schedule resumed two days later and the LED was still off.  Meaning - Sprite works fine, LED doesn't work.  Netro told me to send the unit in over the winter and they will repair the LED.  Awesome - thanks Netro!
All the best,
-Doug
浏览: 9690   回复: 2
Watering Frequency
Andrei Stancovici
更新时间 2020-07-16 05:36:44 UTC
Hello.
I installed my netro yesterday and now after watering all zones it shows me that the next watering will be in 5 days. It seems to be to far away in the future since it's 35 degrees celsius and sunny all day
浏览: 7302   回复: 1
Does Netro whisperer underestimate moisture?
Rick Agrawal
更新时间 2020-07-16 19:12:17 UTC
I added a whisperer to one of our zones. Recently the moisture content was between 25-30%. We are having a hot summer with many days with 110 degrees. I believed it and watered for good 15-20 minutes. It turned out despite all those water the soil moisture went up to 45-50%. I went and checked again, the soil looks pretty good and appeared moist.
Just curious if the whisperer tends to underestimate moisture?
浏览: 7482   回复: 1
I'm not understanding how "estimated frequency and duration" works...
Izio Sem
更新时间 2020-07-18 07:24:18 UTC
Ciao.
Just installed Netro Sprite.
I enjoyed to set up the zones with advanced Smart watering, but I'm not confident with what is reported in "estimated frequency and duration". The frequency showed in the setting page seems too long (e.g. every 6 days)... but, if I see what is scheduled in the calendar it seems much closer to my expectation (e.g. every 2 days).   How daoes it work??
Maurizio
浏览: 8092   回复: 1
Whisperer reset WIFI does not work
ozieaev
更新时间 2020-07-19 14:38:29 UTC
Got 2 Whisperer sensors recently. They came up not new (see some scratches on them and signs of use). As a part of install had to reset WIFI settings in order to connect to my WIFI. Pressing power shows red led. Issue is - pressing power 6 times (should switch to WIFI setup mode), does not work either. Still RED light.
Does anyone knows how to fix this?
浏览: 9128   回复: 4
ifttt or .ics support
Michael Landesman
更新时间 2020-07-20 19:01:42 UTC
浏览: 7543   回复: 1
Centralina offline
Stefano Sabelli
更新时间 2020-07-21 10:08:27 UTC
Buongiorno a tutti,
grazie mille
Saluti
Stefano
浏览: 7420   回复: 1
Rain Delay
R H
更新时间 2020-07-25 04:47:00 UTC
浏览: 7567   回复: 1
更新时间 2020-07-28 05:32:10 UTC
I have an issue/conflict  with the watering adjustments for the sensors and the Smart Zone Sheduling
I have seen something weird.
  • I Have set up the Watering Adjustment for sensors the following I describe o be sure about the problem
  • Moisture to Skip watering 50%
  • Moisture to Add watering 30%
  • Duration 5 minutes (only) -- it is a check
  • The Smart Zones are st up the following
  • Smart Zone - enabled
  • Mode - regular
The watering run today only 5 minutes, when the smart  schedule  defined by the system was above that. As you can see, tomorrow watering says different time runs per zone, but it will run a maximum of 5 minutes. This means that the sensor configuration overrides the Smart Zone. And it should not.
As far as I understand the Watering adjustemt is to add EXTRA watering when needed based on the moisture level. Attached picture
Prior to this setup I had the Duration for Watering Adjustment for 15  and 10 minutes, and you can see in the past days runs, that always run for 15 -10 minutes depending the zone/sensor. - Attached picture
In previous weeks, it was working fine and adding extra watering when need it to keep the moisture levels.
Any idea?
I DID THE CHANGES PROPOSED BY NETRO  and it is not working
Take a look the screen shots
Zones 3,4,5 it is below the 30% trigger
浏览: 8290   回复: 1
Skipped watering on calendar and the system still watered...
Daniel Schoonover
更新时间 2020-07-26 01:36:47 UTC
I noticed system was going to water this afternoon so I skied the watering on the calendar hours before.
When the time came the system still watered my yard?
Why?
And I could not find a single way to stop it.
浏览: 8850   回复: 1
Arthur
更新时间 2020-07-30 22:20:53 UTC
Arthur
浏览: 7484   回复: 1
Water turned off
Ken Laberteaux
更新时间 2020-07-31 01:08:39 UTC
I had to turn off my water valve to my sprinkler system for a week (ending in a few days) and forgot to disable smart watering on my netro.  Netro thinks it did a complete watering last Saturday, and adjusted estimated soil moisture accordingly.  Netro isn't planning another watering for another 9-10 days.  However no watering last Saturday occurred.
How best should I handle this?  Is there a way to delete past watering, which will lower soil estimated moisture, triggering a sooner watering than currently scheduled?  Or should I just do a manual long watering as soon as I can?
浏览: 7930   回复: 1
Centralina non chiude valvola
Stefano Sabelli
更新时间 2020-07-31 18:26:17 UTC
Buonasera a tutti,
Da questa mattina la centralina non mi chiude più la valvola della linea 1 dell’impianto... ho provato a fare reset ma niente continua con irrigazione!!
Sono riuscito a sospendere irrigazione reimpostando da capo la centralina ma il problema e sulla linea 1 che non a trova più anche quando metto programma irrigazione.
Grazie mille
浏览: 9021   回复: 1
Installation help
Francesco G
更新时间 2020-07-31 18:47:07 UTC
Greetings from Italy
this Monday I will receive my Netro Smart Irrigation controller and I have some concerns about the power supply.
On the YouTube video guide I saw there are 2 slots to put the power cables but I was only able to find a regular 24V power adapter with one single output.
Do I have to cut the power jack off and split the cables in order to put them in the controller?
thanks in advance for your help, can’t wait to become part of the Netro family!
this is the power adapter I ordered: Alimentatore 220 V – 24 V/1000mA https://www.amazon.it/dp/B00AWU8NUM/ref=cm_sw_r_cp_api_i_OBgjFbJ8Q41F1
this is the Netro device I ordered: Netro Sprinkler Smart Controller, WiFi, Meteo consapevoli, Accesso remoto, 12 Zone, w/o Adattatore di Alimentazione https://www.amazon.it/dp/B07DGT7ZK1/ref=cm_sw_r_cp_api_i_iCgjFbP0QZ4DH
浏览: 8852   回复: 0
STAN IN NEW JERSEY
Stanleyb3857
更新时间 2020-07-31 18:56:15 UTC
浏览: 7864   回复: 1
Watering "off the books"
wwhitfill
更新时间 2020-08-02 23:26:54 UTC
Right now the watering schedule the Netro program is using for my St. Augustine grass is killing my grass. I live in Dallas and Jully/August is brutal on lawns. If I water outside the schedule the program has established the schedule is changed. Is there anyway for me to water my with Netro and keep the smart watering schedule Netro has? Right now I by pass the Netro by manually engaging my water values, not using Netro.
Will
浏览: 7528   回复: 1
Home Assistant Integration
Giabbino
更新时间 2020-08-03 12:35:09 UTC
Lorenzo
浏览: 8843   回复: 3
Confused about schedule
Bowie Xu
更新时间 2020-08-04 18:52:19 UTC
I am a new user here and just installed the Netro in my house. The “Smart watering” schedule seems very odd to me.
As you can see there are 2 rounds for each zone and the time of zone 4 is about an hour in one round. Is this normal ?
Bowie
浏览: 8039   回复: 1
Fases
Joaquin
更新时间 2020-08-06 13:02:18 UTC
Hola! Acabo de instalar mi Netro al sistema de riego. El el equipo antiguo tenía dos fases, pero ahora la instalación para que funcionara me obligaba a utilizar la celda “M” y me he quedado con una sola fase para todo el riego. Como lo puedo solucionar?
浏览: 8895   回复: 1
