Smart watering
Alejandro Foubelo
更新时间 2020-08-07 01:27:29 UTC
Hello, I set the app to run 3 manual programs on the odds day and I have the smart watering system active on all zones.
Will it skip my watering if there is rain in the forecast on an odd day?
浏览: 7378   回复: 1
Moisture level for lawn
Jan
更新时间 2020-08-08 08:43:43 UTC
Dear community
浏览: 10306   回复: 1
Sensor umidity
Andrea
更新时间 2020-08-09 16:14:57 UTC
I have two sensors installed for a few days but the humidity still marks 98% why?
浏览: 8555   回复: 1
Network error
Fre Camp
更新时间 2020-08-11 22:36:39 UTC
No funcionan los aspersores
浏览: 7294   回复: 2
Lost connection on holidays
lekter
更新时间 2020-08-12 08:45:08 UTC
I'm on vacation and my internet connection has been cut off. I had planned before on netro waterings for the week. Is that without an internet connection in my house, the waterings programmed before will still be done?
Arnaud
浏览: 7539   回复: 2
Battery not holding charge
Steve Walczak
更新时间 2020-08-12 17:49:20 UTC
浏览: 8611   回复: 2
No funciona
Fre Camp
更新时间 2020-08-13 07:40:48 UTC
En la APP todo parece ir bien, pero no riega.
浏览: 8723   回复: 2
What does this mean?
Bowie Xu
更新时间 2020-08-16 16:58:18 UTC
Thanks in advance.
Bowie
浏览: 7670   回复: 1
Unable to reset into Host mode to change WiFi setting
dabo
更新时间 2020-08-16 17:29:54 UTC
I have a 6 zone Netro sprite and need to update my wifi settings. No matter what I do I'm unable to get the Netro to enter host mode. I've tried hitting the RST button numerous times before or after manual reboots (even waiting the full 3+ minutes after re-plugging the device in). I even tried a full manual reset by holding the RST button for 10 seconds and the device still doesn't reset. I'm starting to doubt whether the reset button on my device works.
Has any one had any similar problems or pointers for just getting the Netro to join a new WiFi network? I'd rather not do a full reset and lose my zone settings, but at this point I've even tried that and can't get that working.
浏览: 8846   回复: 2
Arthur
更新时间 2020-08-20 03:58:15 UTC
浏览: 7092   回复: 1
Battery not charging
Petar Nedyalkov
更新时间 2020-08-21 18:24:41 UTC
My solar powered controller doesn’t charge its battery - not sure if it’s a battery problem - the controller is under direct sunlight for at least 6 hours every day.
I’ve set it to water for 1 hour every day so it’s a simple On/Off once a day.
Have other people had this issue?
浏览: 9302   回复: 2
Add manager
Fabio Pellizzoni
更新时间 2020-08-27 08:26:50 UTC
浏览: 7180   回复: 1
water connection of Pixie
graziani
更新时间 2020-08-27 08:29:42 UTC
can you please confirm sizes of water connection, I don't find on the website
浏览: 8643   回复: 1
What about your API ?
更新时间 2020-08-29 17:19:23 UTC
Christophe
浏览: 8237   回复: 2
Keeps watering even though it rains
Oleg Frayman
更新时间 2020-09-02 01:51:56 UTC
My sprinklers keep watering even though skipping if it rains is selected with low threshhold
浏览: 6950   回复: 1
Email too long in android app
Christoforos
更新时间 2020-09-02 09:49:14 UTC
浏览: 7159   回复: 1
Whisper sensor
Randle Griffin
更新时间 2020-09-03 04:18:11 UTC
浏览: 6854   回复: 1
Sensor watering adjustment doesn't work - bug
Roman Stanek
更新时间 2020-09-04 04:49:34 UTC
I installed two sensors today and added watering adjustment so that every time the humidity goes below 10% another 10 minutes of watering is added. Unfortunately, there is a bug and the watering time is triggered right away even though the faucet timer connects only every three hours. The additional watering time needs to be scheduled after the next timer sync and not right away. It's a clear bug.
浏览: 7178   回复: 1
controller kept go offline
更新时间 2020-09-05 01:12:13 UTC
Hello, wondering why my watering controller kept going offline.  Once turning it off/on, it will goes online again but will go off in several hours later.  Is it time for me to get a new controller?  I hope not
浏览: 9569   回复: 2
Remove Plant Sensor dropdown
Scott McKay
更新时间 2020-09-05 21:09:40 UTC
浏览: 6885   回复: 1
