How stop 1 day
Leonardo Antonucci
更新时间 2020-10-11 18:33:55 UTC
浏览: 6851   回复: 1
"Next in" shows "--"
Luis Aguilar
更新时间 2020-10-14 18:45:01 UTC
浏览: 6928   回复: 1
Netro unit
Bhumit Joshi
更新时间 2020-10-16 18:15:51 UTC
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
浏览: 8327   回复: 1
Problem With application
Alex Guerrero
更新时间 2020-10-17 08:21:08 UTC
浏览: 6900   回复: 1
Manually entering rainfall
Curt Lizzi
更新时间 2020-10-17 13:16:09 UTC
浏览: 7334   回复: 1
David Farries
更新时间 2020-10-24 20:24:40 UTC
浏览: 7260   回复: 1
Email address length
Alberto Castro Hinojosa
更新时间 2020-10-24 21:37:57 UTC
Could you review please?
浏览: 8438   回复: 1
Stefan Pena
更新时间 2020-10-25 10:41:41 UTC
Hey guys!
浏览: 6833   回复: 1
New user
Haris Eliades
更新时间 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
浏览: 7021   回复: 1
How do I turn off for Winter?
Paul A
更新时间 2020-10-30 20:59:47 UTC
浏览: 6914   回复: 2
Add zones manually in queue
Haris Eliades
更新时间 2020-11-03 04:04:49 UTC
浏览: 7211   回复: 1
Didn’t water. Exclamation point inside of triangle
更新时间 2020-11-03 11:05:39 UTC
Controller didn’t turn on sprinklers at 0400hrs today.  Instead schedule shows yellow triangle with exclamation symbol, but gives no breakdown on why system didn’t turn on water.  If controller shows exclamation, it would be nice if it showed an actual description of problem/event.
浏览: 9405   回复: 1
dinzdale
更新时间 2020-11-03 16:00:28 UTC
浏览: 6954   回复: 1
Curt Lizzi
更新时间 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
浏览: 7465   回复: 1
Offline buy watered
Haris Eliades
更新时间 2020-11-09 06:22:11 UTC
浏览: 7070   回复: 1
Stan Balafas
更新时间 2020-11-16 17:52:28 UTC
Thank ypu
浏览: 6879   回复: 1
Jens Wymeersch
更新时间 2020-11-17 13:25:17 UTC
Dear,
Thank you so much,
Jens
浏览: 8034   回复: 2
App stuck on Idle
Pam Manwaring
更新时间 2020-11-18 02:21:16 UTC
浏览: 6790   回复: 1
Sensor and zone of control
Andrea Pieri
更新时间 2020-11-20 19:49:29 UTC
Dear support right now i am installing my new sensor connected with netro controller ( this is the first sensor) . I have 5 zone active but sensor is able to control just 3 zone is possibile to extend the sensor control  to a global of 5 zone for one sensor ? Thanks for your help .
浏览: 8634   回复: 1
Whisperer Battery
growerken
更新时间 2020-11-23 16:44:00 UTC
I have one whisperer,used in indoor garden.it looks like the solar is not enough for the charging.
Any idea I can fix it?
浏览: 9040   回复: 1
