Temporarily stop all watering
Williams
更新时间 2020-09-07 15:57:32 UTC
How do I temporarily stop all watering without losing the programming?
浏览: 8425   回复: 1
Netro and Google home
Cesar
更新时间 2020-09-08 08:26:17 UTC
HI
Could you please help
浏览: 6676   回复: 1
Shut down for winter
Chad Fuller
更新时间 2020-09-10 02:01:10 UTC
浏览: 7712   回复: 1
Rain Snow Delay
R H
更新时间 2020-09-10 03:35:37 UTC
浏览: 7084   回复: 1
IFTTT - Watering Schedule
更新时间 2020-09-10 05:56:28 UTC
Thanks in advance,
浏览: 7516   回复: 1
Way to add weather stations
Curt Lizzi
更新时间 2020-09-12 01:16:55 UTC
I find the Weather apps to be very inaccurate with respect to rainfall at my home. Is there a way to add a near by weather station for better accuracy?
浏览: 7416   回复: 1
Potted plant on terrace
Andrea Zorgniotti
更新时间 2020-09-14 07:46:03 UTC
Hi I Have a big terrace with many plants divided in 3 zone controlled by Netro. To use the smart watering and have an acceptable time/frequence for watering (6 min every 2.5 days) I have to set user and from 80% to 85% umidity. If I set frequent or extra water the estimated frequency is 4/5 days. Considering in summer my setting seems nor giving enough water to plants what kind of setting do you suggest to increase the frequency (change msq, kind of sprinkle or whatever).
Thanks in advance for answer
浏览: 7339   回复: 1
loose connection on install
Lawrence Jones
更新时间 2020-09-15 22:49:22 UTC
The unit is working good, yeah!  The way the wires get tab/push for contact is really cheap.  The "spring" of the contact is very , very loose.
Move the wire at all and no contact.  Then trouble shooting to find where trouble is.  Not a good design. Need a much more firm grip on the bare wire. something else or just poor quality?
浏览: 8536   回复: 1
Start time change
Franco Storato
更新时间 2020-09-16 06:00:59 UTC
Thank you in advance,
Franco
浏览: 6712   回复: 1
Contact
Santiago Errazuriz
更新时间 2020-09-16 14:44:36 UTC
Hello good morning, greetings from Chile. I need to know if I can have a whatsapp or contact email.
浏览: 8183   回复: 1
Simple on/off
gmcg1984
更新时间 2020-09-17 01:54:35 UTC
浏览: 6911   回复: 1
Multiple sprinklers in one zone - and is there a Test System ?
Cormac Champion
更新时间 2020-09-19 13:48:55 UTC
Can zones be setup with several sprinklers in the one zone ?  From what I can see from another question, is it correct that you setup the aproximate size of each zone ?  I have several zones with maybe 10 sprinklers in each zone, with sprinklers about 3m apart.
Also, is there any access to a test / simulation system that I can setup my location and see how well it would adapt to weather.  I am planning the installation for southern Spain
Thanks in advance
浏览: 7439   回复: 1
HomeOwner
Isaac Fishman
更新时间 2020-09-21 01:14:55 UTC
浏览: 8219   回复: 1
Controller LED Light
Texas AF
更新时间 2020-09-22 14:01:57 UTC
浏览: 7044   回复: 1
Second house
Dave Hornsey
更新时间 2020-09-29 18:20:51 UTC
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
浏览: 8454   回复: 1
Atif Khan
更新时间 2020-10-01 14:21:57 UTC
浏览: 6862   回复: 1
OFFLINE
Javier López-Guerrero
更新时间 2020-10-03 08:20:26 UTC
Help!
Javier
浏览: 6848   回复: 2
Switch Off automatically
Carlos Jimenez
更新时间 2020-10-09 20:18:31 UTC
I found two cases,
浏览: 6928   回复: 1
Simone Nolletti
更新时间 2020-10-11 11:46:06 UTC
Buonasera,
浏览: 7591   回复: 1
Questions about Netro app
Luis Aguilar
更新时间 2020-10-11 17:47:55 UTC
浏览: 7091   回复: 1
