Kevin Westling
更新时间 2021-03-28 06:40:48 UTC
浏览: 6973   回复: 1
更新时间 2021-03-29 08:57:05 UTC
I have checked in the smart schedule that tomorrow is programmed to run zones that should be skipped.
I have set up the whisperer to skip run if moisture is above 40%. Current moisture is:
  • Zone 2 - 92%
  • Zone 5 - 70%
浏览: 7558   回复: 2
Server offline
Mirko Paganelli
更新时间 2021-03-30 16:15:01 UTC
浏览: 7127   回复: 1
What do the icons mean?
Jim Stichbury
更新时间 2021-03-31 06:55:06 UTC
浏览: 6820   回复: 1
Firmware update
Francesco Angelone
更新时间 2021-04-01 13:33:34 UTC
my firmware version is the 1.1.1
Please, can I have the last firmware vesion and the instructions for update my controller.
The serial number is E4956E4B6B05
浏览: 8509   回复: 1
Light flashing
lightnin
更新时间 2021-04-01 19:11:23 UTC
Why is my light flashing on my Netro?
浏览: 8120   回复: 2
Instant watering
hermanins@gmail.com
更新时间 2021-04-03 00:01:28 UTC
浏览: 6605   回复: 1
Many inexplicable Manual runs
Panos Charalambopoulos
更新时间 2021-04-03 11:37:15 UTC
Hello everyone ,
浏览: 8260   回复: 1
Does the Pixle have to be installed with the water coming into it on the "Hose Faucet Connection" side?
Austin Franklin
更新时间 2021-04-03 19:04:13 UTC
Basically, is the Pixie water control valve one way, or can it shut off/turn on with pressure from either side?  In order to install it so the button faces up, I need to install it so the water comes in what is labeled as the "Outlet" side.  I don't know if it's labeled "Outlet" because it is a male connection, or because it cares about the direction of the water.  Otherwise, I will need to buy a male/male and female/female adapter, flip it "upside down" and use it with the button facing down.
浏览: 8046   回复: 1
Can’t start Netro
Joe Horner
更新时间 2021-04-05 14:47:49 UTC
I have a good WiFi signal.
浏览: 6592   回复: 1
jjmengibar
更新时间 2021-04-05 18:16:46 UTC
How can I reset any zone
浏览: 7398   回复: 1
jjmengibar
更新时间 2021-04-05 18:19:11 UTC
浏览: 8855   回复: 1
David Farries
更新时间 2021-04-07 02:16:14 UTC
浏览: 6914   回复: 1
Abel Vargas
更新时间 2021-04-09 00:49:42 UTC
浏览: 11453   回复: 1
Adding multiple sensors to a Pixie
phatd
更新时间 2021-04-09 18:13:11 UTC
I have a mister setup with multiple Herb racks and raised garden beds. I just got a Pixie and a few Whispers. My hope was using one Pixie and monitoring each bed with a whisper. Is this possible? Can I create multiple zones? Is this something going forward that might be possible? I don't want to set them up as standalones.
浏览: 8160   回复: 1
Moisture Level
Des Mullin
更新时间 2021-04-09 23:48:09 UTC
浏览: 7278   回复: 1
Disable a zone
fernando colon
更新时间 2021-04-10 14:15:21 UTC
浏览: 11356   回复: 1
How to delete a device
Scott Gustafson
更新时间 2021-04-10 16:04:18 UTC
Scott
浏览: 7449   回复: 1
Timezone not supported
Shai Amiel
更新时间 2021-04-11 19:33:24 UTC
why do i get this error? I am trying to install in israel
浏览: 8265   回复: 1
Imran Ali
更新时间 2021-04-12 22:54:05 UTC
Imran Ali
浏览: 7111   回复: 1
