Smart things?
S D
更新时间 2020-06-01 23:14:05 UTC
浏览: 6872   回复: 0
Moisture to Skip Watering
更新时间 2020-06-02 23:59:08 UTC
浏览: 7865   回复: 1
Netro Sprite non apre le valvole
Simone Nolletti
更新时间 2020-06-03 09:40:36 UTC
valvole hunter 24vac, netro non apre le valvole.
i collegamenti sono stati eseguiti come da istruzioni.
Quale può essere il problema?
Alimentatore 24v 1000ma e’ corretto?
浏览: 10307   回复: 1
Watering metrics question
Egan
更新时间 2020-06-03 16:09:22 UTC
Todd in Texas
浏览: 7667   回复: 2
Metrosideros (Myrtaceae)
Alessandro Raffi
更新时间 2020-06-03 21:09:16 UTC
Thanks a lot,
Ale
浏览: 12272   回复: 1
Notes section per zone
Simon Clark
更新时间 2020-06-04 07:13:33 UTC
浏览: 7883   回复: 1
Timer
Gary Niederpruem
更新时间 2020-06-04 12:08:43 UTC
浏览: 7244   回复: 1
Upgrading from 6 to 12 zones
Carlos Oliveira
更新时间 2020-06-05 21:10:19 UTC
浏览: 10004   回复: 1
OPCIONES
Ernesto
更新时间 2020-06-06 16:01:17 UTC
浏览: 8457   回复: 1
A way to dial it down
esassone
更新时间 2020-06-07 01:51:41 UTC
浏览: 7162   回复: 1
Simone Nolletti
更新时间 2020-06-07 19:32:59 UTC
浏览: 9932   回复: 1
Thanks for IFTTT
Joe Ryan
更新时间 2020-06-07 22:38:39 UTC
浏览: 7710   回复: 1
JDWalburg
更新时间 2020-06-08 15:26:52 UTC
浏览: 7237   回复: 1
Jason Wire
更新时间 2020-06-08 21:50:29 UTC
浏览: 7398   回复: 1
Rain Delay
R H
更新时间 2020-06-10 03:03:28 UTC
Why or how does the rain delay option work?
Mine is set up with the minimum rain but the program still goes off no matter what.
My B-hyve sends me a “rain delay” message.
浏览: 10155   回复: 1
Andrey
更新时间 2020-06-10 04:38:59 UTC
浏览: 7321   回复: 1
Maegan Nelson
更新时间 2020-06-10 08:59:42 UTC
浏览: 7431   回复: 1
Insqm
Simone Nolletti
更新时间 2020-06-11 14:23:08 UTC
metri quadrati ?
pollici quadrati ?!
浏览: 7682   回复: 1
Ryan Sciandri
更新时间 2020-06-11 19:55:28 UTC
浏览: 9168   回复: 1
Mark Poppen
更新时间 2020-06-12 01:34:57 UTC
浏览: 8901   回复: 1
