Curt Lizzi
Updated at 2020-11-03 18:41:08 UTC
Am I doing something wrong?
Curt
View: 7457   Answer: 1
dinzdale
Updated at 2020-11-03 16:00:28 UTC
View: 6944   Answer: 1
Didn’t water. Exclamation point inside of triangle
Updated at 2020-11-03 11:05:39 UTC
Controller didn’t turn on sprinklers at 0400hrs today.  Instead schedule shows yellow triangle with exclamation symbol, but gives no breakdown on why system didn’t turn on water.  If controller shows exclamation, it would be nice if it showed an actual description of problem/event.
View: 9398   Answer: 1
Add zones manually in queue
Haris Eliades
Updated at 2020-11-03 04:04:49 UTC
View: 7203   Answer: 1
How do I turn off for Winter?
Paul A
Updated at 2020-10-30 20:59:47 UTC
View: 6904   Answer: 2
New user
Haris Eliades
Updated at 2020-10-28 20:35:38 UTC
Hello!
Zone 4, 2 minutes
Zone 5, 2 minutes
Zone 1, 4 minutes
Zone 2, 4 minutes
Zone 3, 4 minutes
Zone 4, 4 minutes
Zone 5, 2 minutes
View: 7011   Answer: 1
Stefan Pena
Updated at 2020-10-25 10:41:41 UTC
Hey guys!
View: 6823   Answer: 1
Email address length
Alberto Castro Hinojosa
Updated at 2020-10-24 21:37:57 UTC
Could you review please?
View: 8427   Answer: 1
David Farries
Updated at 2020-10-24 20:24:40 UTC
View: 7251   Answer: 1
Manually entering rainfall
Curt Lizzi
Updated at 2020-10-17 13:16:09 UTC
View: 7325   Answer: 1
Problem With application
Alex Guerrero
Updated at 2020-10-17 08:21:08 UTC
View: 6889   Answer: 1
Netro unit
Bhumit Joshi
Updated at 2020-10-16 18:15:51 UTC
I just got my system winterized today. Netro box is still on. Do i just unplug it for the winter?
View: 8319   Answer: 1
"Next in" shows "--"
Luis Aguilar
Updated at 2020-10-14 18:45:01 UTC
View: 6918   Answer: 1
How stop 1 day
Leonardo Antonucci
Updated at 2020-10-11 18:33:55 UTC
View: 6841   Answer: 1
Questions about Netro app
Luis Aguilar
Updated at 2020-10-11 17:47:55 UTC
View: 7082   Answer: 1
Simone Nolletti
Updated at 2020-10-11 11:46:06 UTC
Buonasera,
View: 7572   Answer: 1
Switch Off automatically
Carlos Jimenez
Updated at 2020-10-09 20:18:31 UTC
I found two cases,
View: 6921   Answer: 1
OFFLINE
Javier López-Guerrero
Updated at 2020-10-03 08:20:26 UTC
Help!
Javier
View: 6842   Answer: 2
Atif Khan
Updated at 2020-10-01 14:21:57 UTC
View: 6850   Answer: 1
Second house
Dave Hornsey
Updated at 2020-09-29 18:20:51 UTC
I'm in the very fortunate position of having 2 homes - one in the UK and one in Spain. We've just had the garden reworked in the UK and I've been able to install an irrigation system controlled by a single Sprite controller.
I'm very pleased with how this is working - and now want to upgrade the manual irrigation system we have in our Spanish house to a smart system. Can Netrohome / the (Android) app manage 2 different irrigation systems in 2 different locations (with 2 very different climates)?
Many thanks.
View: 8439   Answer: 1
