winterizing
Ken Siebert
Updated at 2018-09-29 11:26:05 UTC
How best to winterize system
View: 10119   Answer: 1
App Crashesdevice
Aaron Miller
Updated at 2018-09-16 11:28:35 UTC
The app crashes on android phone (S8) when attempting to set rain preferences. This is annoying. None of my messages regarding this have been answered by tech support. Perhaps I should return the device and get a Rachio?
View: 9141   Answer: 0
Updated at 2018-09-12 07:54:55 UTC
Resources:
View: 485805   Comment: 308
New grass seed
Dan R
Updated at 2018-09-09 21:47:24 UTC
It would be great to have a feature that runs the sprinklers three times a day for 7 days when I put down new grass seed. I can build a program for this and it does not take very long. It would be a nice feature to have this built into the app.
View: 10022   Answer: 1
Sprite not running zones after power outage
Rob Platko
Updated at 2018-09-08 17:28:57 UTC
Hi, my Sprite does not run any program on any zone following a power outage.  The zones are scheduled, I can see them in the calendar, but they don’t run.  Anyone seen this problem?
View: 9431   Answer: 0
Program for new grass seed?
Brian Killian
Updated at 2018-09-04 11:18:30 UTC
Does netro have a program for new grass seed?  I'm going to oversees later this month and was wondering how to set my sprinklers to get the seed to grow.
View: 9869   Answer: 1
Netro app not work
Rodrigo Echeverria
Updated at 2018-08-31 20:40:48 UTC
with the new update ios 11.4.1 does not work. the app starts and then stops working,
resets itself
View: 10152   Answer: 1
Alexa skill with multiple Netro controllers?
James Nyazai
Updated at 2018-08-29 21:13:54 UTC
I have 2 Netro controllers named Front Yard and Back Yard. Alexa can water the Back Yard just fine by specifying a zone and a time to water for. But how do I switch controllers so Alexa will water zones on the Front Yard controller?
View: 10376   Answer: 0
Mike Cotten
Updated at 2018-08-26 17:49:23 UTC
The sensor shows 0 lux and is in direct sun. Does the black film over the PV panel get removed?
View: 11358   Answer: 2
How do you set weather cancelling programs
Richard Spooner
Updated at 2018-08-24 01:08:49 UTC
Can’t figure out how to have the weather app stop the sprinklers
View: 10548   Answer: 1
Reset moisture level
Geoffrey Maslin
Updated at 2018-08-22 23:07:11 UTC
Is there a way to reset the moisture level for a zone. It is currently showing 100% but soil is dry.
View: 10509   Answer: 1
Historical usage
sihler
Updated at 2018-08-20 23:38:11 UTC
Is there a way to see raw historical water usage in time per zone?
View: 10021   Answer: 1
What percentage is ideal for the moisture content for a summer lawn in Southern CA?
Gary Riehl
Updated at 2018-08-17 18:05:53 UTC
Can you please tell me the ideal percentage for the top soil and sub soil for a Southern CA. lawn in summer?  Does this number change during the other seasons?
Gary
View: 12552   Answer: 0
California Native Plants
Anthony M
Updated at 2018-08-08 22:15:43 UTC
It would be nice if more California native style plants (dry climate) were included in the database - or at least that sort of watering style (much less frequent/deep) be available as an option.  I find that when relying on the smart watering with generic salvia hybrid selected for plant type, the water usage is actually higher than the manual program i had set before, especially now in summer months I feel it might be overcompensating.  I'd like to be able to rely on the "smart" aspects, but not sure it makes sense given the higher water usage so for now will probably be forced to go back to manual programming instead.. If anyone has some experience/suggestions on matching these types of plants up with what is in the database I'm all ears as well.  Thanks!
View: 10896   Answer: 2
Redwood pine tree
Javier Gutierez
Updated at 2018-08-08 18:32:32 UTC
Hello. I'm setting a zone in where i have to water Redwood pine trees. I was looking for them under the species/type. I can't find it. I tried different names, species, etc. I believe it's not available yet.
Please, could you help me with:
Letting me know which tree available within the app will be more suitable to cover Redwood pine tree needs
Updating, if it is possible, the trees list available in the app
Thanks in advance.
View: 10012   Answer: 1
Rain vs moisture
Updated at 2018-08-06 01:15:02 UTC
Wonder why the soil moisture doesn't change to 100% after a big rain in my area?  The soil moisture percentage is important since this might trigger the auto watering (water will kick in when the max moisture setting is greater than the actual moisture  percentage)
View: 11061   Answer: 1
Offline alert
Alex R
Updated at 2018-08-05 19:29:29 UTC
Is there a way to get the Netro system to alert me if the system goes “offline” . I have had to instantes where the system was off line and my plants almost died
View: 11938   Answer: 6
Two zones on same spot
Updated at 2018-07-31 22:06:08 UTC
I have 4 zones. Two of these cover the same piece of ground. One zone has pgm sprayers and the other zone has regular sprayers .But they cover exactly the same area. How do I tell the app this so that it knows that running the sprinklers for one zone waters the same trees and grass as the other zone?
To try and clarify the question - these zones cover the same physical piece of ground, (they overlap 100%) but netro doesn't know that, so it will water one zone and think the other zone is still in need of watering - and thus water the same grass twice. (each zone once so the same grass twice).  Netro's algorithm for determining soil moisture levels can't work if it doesn't realize these two zones are the same physical piece of grass.
View: 11456   Answer: 2
Accuracy of dark sky in Canada
Updated at 2018-07-31 03:16:54 UTC
The dark sky android app is not available in Canada  so I wonder how accurate their weather is here.  To try and determine this for myself, I looked at the netro temperature graph..  Today it is 34C at my house  but the temperature summary graph in  Netro says it is only 22C. (for my friends still using Fahrenheit that is about a 24F difference )  Does anyone know when Netro gets the temperature that it uses in the graph? Other thoughts on dark sky accuracy in Canada?
View: 10839   Answer: 1
Netro and Alexa
Updated at 2018-07-30 22:29:36 UTC
I've loaded the Alexa skill for Netro. When I tell Alexa to ask Netro to water a zone, it just looks up references for "metro" instead. Much as I appreciate Alexa looking up train schedules for me, I'm curious if others have had this problem.  I've tried pronouncing  it "net row" and "neat row" but  neither gets recognized.
This isn't a critical issue, as I'm not sure I would ever see the point in voice control over my sprinklers  but thought I would set it up to try anyway
View: 10940   Answer: 1
