Valves Not Opening
Micky Boles
Updated at 2026-08-09 21:16:47 UTC
Netro controller has run fine for 3 or 4 years. Trouble arose overnight. Controller is connected to my WiFi and no lights blinking,  it if I do, say, a manual run, it sends the command to the controller, and the app thinks it is running water, but the valves aren't opening. Have tried to do this with multiple valves, have reconnected to WiFi, etc but can't make it open valves. Ideas?
View: 1958   Answer: 1
Purchasing a moisture sensor
Gyade B.
Updated at 2026-08-09 15:34:55 UTC
How do I purchase a Netro Controller moisture sensor?
View: 2368   Answer: 1
Soil Moisture Readings
dougt425
Updated at 2026-08-06 16:06:01 UTC
I currently have several Netro Whisperer 2 sensors and receive moisture, temp and solar readings. But i also have other soil sensors - e.g., Ecowitt. The two sensors appear to measure soil moisture on different scales. Can someone - from Netro - explain to me clearly how the Whisperer measures moisture and how I should interpret different readings in the same bed (e.g., Ecowitt measures 28%, Whisperer measures 96%).
View: 1918   Answer: 1
Updated at 2026-08-06 07:50:00 UTC
Dear Netro Community,
What We Are Doing
📧 support@netrohome.com
Best regards,
Netro Support Team
View: 10443   Comment: 0
Pixie and smart water sensor
Thomas Lamb
Updated at 2026-07-26 12:29:27 UTC
Is there any way to use the smart plant sensor gen 2 with my pixie?
View: 1976   Answer: 1
Pixie and Amazon drop irrigation
Thomas Lamb
Updated at 2026-07-26 12:25:28 UTC
I added a pixie to my system and hooked it up to a drop irrigation system from Amazon. My deck plants survived my summer vacation away from them.
View: 2013   Comment: 1
Pixie
Magnus Swenson
Updated at 2026-07-12 18:45:13 UTC
Can you add external choice vs plants ; this device can actually have multiple use like pool filler timer etc thank you ! Pixie 1 solar hose timer
View: 2205   Answer: 2
Using Netro Watering on Polyglot 3x
Peter Henneberry
Updated at 2026-07-12 17:13:10 UTC
Anyone using the universal devices polyglot plugin for Netro version 0.1.18
In the configuration it states to use my serial number from the Netro Spark which I see on the Netro app but when I add it and click save, Polyglot says it is an invalid serial number
View: 2064   Answer: 0
Help!!!!
Sylvie Giacinti Vincent
Updated at 2026-07-12 05:23:45 UTC
My husband suddenly die !! I don t understand nothing with Netro because he used to manage it on his phone
How can I join some one in France to explain me how can I use it now  I am totally list and désespérate
Please help me 😢😢
View: 2125   Answer: 1
Help!!!!
Updated at 2026-07-12 05:23:08 UTC
Please help me 😢😢
View: 2247   Answer: 0
Controller
rodrigo6760
Updated at 2026-07-10 12:33:26 UTC
Cómo puedo borrar un controller que aparece en la app y que ahora ya no está funcionando ? Aparece fuera de línea y no puedo borrarlo.
Muchas gracias
View: 2231   Answer: 1
Wrong location detected: Italy address is always converted to Oklahoma, USA
tizzy
Updated at 2026-07-02 10:11:39 UTC
I have a Netro Spark 8 controller installed in Italy.
My address is:
Via Gonfalone 49
73031 Alessano (LE)
Italy
However, Netro always changes my location to:
  • ZIP code: 73032
  • State: OK
  • Country: United States
Because of this, the weather forecast is completely wrong and Smart Watering is using incorrect weather data.
I cannot edit the ZIP code, state or country, either in the Android app or on the web interface.
Could you please help me fix my location or update your geolocation database?
View: 2194   Answer: 1
Netro Smart Settings
caravagg
Updated at 2026-06-30 11:58:32 UTC
netro smart settings, please rank relative seasonal water use from high to low for the different settings: EPA, Boost, New Plant, Deep, Frequent, Regular, ECO
No water coming from sprinklers of 3 zones
Sukesh Arora
Updated at 2026-06-28 15:31:51 UTC
Although the App says that it is watering a particular zone but no water comes out of the sprinkler heads. What could be causing that?
View: 2246   Answer: 1
Sukesh Arora
Updated at 2026-06-28 15:23:05 UTC
View: 2210   Answer: 1
Netro Skill
ghutch2262
Updated at 2026-06-26 14:52:07 UTC
The netro skill does not stay connected to Alexa.  What is the issue with that?
View: 2325   Answer: 1
How does eco factor work?
Updated at 2026-06-21 16:02:22 UTC
View: 2291   Answer: 1
Nuovo wi fi e luce spenta
Paolo Grippa
Updated at 2026-06-21 08:13:39 UTC
A seguito di nuova installazione wi fi fibra home, il dispositivo mi da luce spenta come se non arrivasse corrente, ma in realtà la corrente arriva. Ho infatti provato a staccare e riattaccare tutto ma la situazione non cambia. Quale può essere il problema?
View: 2247   Answer: 1
Es un problema
Alejandro Miguel
Updated at 2026-06-17 20:34:07 UTC
El programador es un verdadero rollo deja de tener conexión no actúa riega cuando le da la gana no lo recomendaría jamas
View: 2936   Comment: 1
Notificaciones
Peter urrielu
Updated at 2026-06-14 07:59:40 UTC
Hola, en la sección de notificaciones de la aplicación, no hay nada, no hay ningún tipo de notificaciones para elegir. Es un problema de la versión de la aplicación o es un problema mío?. Gracias
View: 2606   Answer: 1
