Pause
Tamgar chan
Updated at 2025-07-19 10:59:15 UTC
View: 7603   Answer: 1
Franck FONTANEL
Updated at 2025-07-18 19:49:49 UTC
I don’t know why ?
View: 7310   Answer: 1
Daniele Fuccio
Updated at 2025-07-18 17:17:18 UTC
What could the issue be?
Thank you in advance
View: 5423   Answer: 1
nsutherland
Updated at 2025-07-14 01:33:11 UTC
View: 5090   Answer: 1
Ricardo Ribeiro
Updated at 2025-07-12 13:05:48 UTC
Can you help?
View: 5427   Answer: 1
Updated at 2025-07-10 18:58:03 UTC
Kirk
View: 5433   Answer: 1
Spark 8 zones
Jesus Laso
Updated at 2025-07-10 13:05:31 UTC
Good afternoon,
Thais in advance
View: 7718   Answer: 1
WEATHER CONDITIONS - Rain
Zsolt Karman
Updated at 2025-07-08 10:23:15 UTC
Hi Team,
Could you please ?
Controller SN: 0cb815314670
Regards, Zsolt
View: 7828   Answer: 1
Sensors missing
dano
Updated at 2025-07-06 00:06:15 UTC
Dan
View: 7816   Answer: 1
Gyade B.
Updated at 2025-07-03 23:32:35 UTC
View: 7592   Answer: 1
Umidità terreno
Alessandro Zannini
Updated at 2025-07-03 19:20:15 UTC
View: 8019   Answer: 1
Whisperer 1 Dead
Updated at 2025-07-03 15:13:13 UTC
View: 7832   Answer: 0
Veronica Slaughter
Updated at 2025-07-03 12:43:45 UTC
View: 7323   Answer: 0
Wifi error
nvenezia
Updated at 2025-07-02 14:51:10 UTC
View: 7546   Answer: 2
Valve not opening
Updated at 2025-07-01 05:11:54 UTC
I have a Netto controller 12
View: 6937   Answer: 1
Unified controllers
Gianluca Spada
Updated at 2025-06-29 20:59:51 UTC
View: 7259   Answer: 1
Valve compatible with Netro
Francesco Manella
Updated at 2025-06-29 10:55:38 UTC
Hi everyone,
Thanks to every can help me
View: 7573   Answer: 0
Multiple controllers — 1 app?
Jordan B
Updated at 2025-06-28 07:48:22 UTC
View: 7017   Answer: 1
Font size/ dark mode
Updated at 2025-06-28 04:53:19 UTC
View: 7240   Answer: 1
Jack De Donato
Updated at 2025-06-26 11:48:52 UTC
Question in subject title
View: 6782   Answer: 0
