Francesco Gritti
Updated at 2025-08-29 16:39:06 UTC
View: 7037   Answer: 1
Updated at 2025-08-24 22:55:28 UTC
View: 7287   Answer: 1
Non riesco a connettere metro spring con metro wisperer
Fabio Doc
Updated at 2025-08-23 07:43:08 UTC
View: 7288   Answer: 1
Interoperability with Alexa, Homey, any other smart home platform?
arnaud@brucy.org
Updated at 2025-08-22 19:03:11 UTC
Is there any interoperability/integration existing or planned with home automation/smart home platforms?
Integration with Homey Pro would be great, being able to fetch the watering status for each zone, start a manual watering, or send some external triggers (humidity, rain water tank level, etc.)
Thank you !
Arnaud
View: 6974   Answer: 2
Pixie valve won’t close
Geoff Miller
Updated at 2025-08-22 16:06:03 UTC
One, and only one ,of my 4 Pixies occasionally sticks in open mode, not closing the valve, watering until I notice it. It won’t shut down from button and I have to turn it off or remove battery to get it to reset. It works for a few days and happens again. It has been working well for about 6 months. Any ideas how to fix this?
View: 7014   Answer: 2
Remote reboot of whisperer
Updated at 2025-08-17 14:48:38 UTC
Is there a way to remotely reboot a whisperer sensor?
I am on vacation adn one of the sensors is showing up weird values in all the parameters.
View: 7045   Answer: 1
help Netro Spark 6
Andrea Giannelli
Updated at 2025-08-14 09:03:33 UTC
Hi everyone,
Despite these attempts, the problem persists.
Thenks
View: 7154   Answer: 1
Whisper not showing any moisture reading at all
Updated at 2025-08-12 02:45:00 UTC
Why is Whisperer not showing any moisture reading at all? after working fine for days, it just stops sending moisture info
View: 7227   Answer: 1
Spark 16 works only in manual
Davide Riva
Updated at 2025-08-11 21:55:04 UTC
Hello, I’ve installed netro app on my iPhone, followed the procedure to connect the spark 16 and everything is fine, but when I try to activate valves with the app, the led turn white.
If I remove spark 16 from the app, the led turn green and I can only activate valves from the controller,
Any solution?
Davide
View: 7106   Answer: 2
Problem: Spark 8 controller stuck on "in communication"
Stefano F
Updated at 2025-08-10 07:01:41 UTC
Hi everyone,
I'm experiencing a serious issue with my Netro Spark 8 controller. It connects correctly to Wi-Fi and appears online in the app, but when I try to start irrigation manually, the app just stays on "in communication" and nothing happens.
Despite these attempts, the problem persists. I also tested the solenoids with a multimeter, and they’re working correctly. If I activate the valves directly from the controller, they respond as expected—so it’s clearly not a hardware issue.
I should also mention that I previously had the same problem with two Sprite6 controllers. That’s why I switched to the Spark 8, hoping it would solve the issue. Unfortunately, it hasn’t.
To make matters worse, scheduled programs aren’t working either.
This is an urgent situation because my plants are currently without water. I’d really appreciate any help or suggestions to resolve this.
Thanks in advance,
Stefano
View: 4775   Answer: 2
Updated at 2025-08-10 00:01:57 UTC
View: 4700   Answer: 1
App reports off-line, controller is on-line and web based app is on-line
Jorge Rodrigues
Updated at 2025-08-08 18:46:45 UTC
I have a strange situation:
- App reports controller as off-line, sometimes it reports on-line for brief periods. It was working fine till three days ago
- Controller has green light
- Web app on the netro site reports on-line and works
- The controller is watering
- The Wifi near the controller is working and I have not changed the password or settings
- I have tried forcing it to change the wifi, I get the bluetooth light and the controller is detected on the app via bluetooth, however it fails after I insert the password for the wifi. This is odd since the device is connected.
I suspect there is a synch issue between the App and your servers. Help would be appreciated.
View: 4454   Answer: 1
Interpretation of soil moisture readings by Whisperer
Missy Bartell
Updated at 2025-07-26 12:13:30 UTC
I have two Whisperers that I move around to various parts of my graden to get comparative readings of sunlight and soil moisture.  I really do not know how to interpret the moisture readings which generally range from 50% to 98% but can be as low as 30%.  Soil type varies from a clayey loam to heavy clay.   How do I know when watering is required?  Does the meter measure the capillary water?  The adhered water?  The percentage of voids filled with water?  How does Netro calculate the percentage of water and what do the readings mean?
View: 5500   Answer: 1
Watering time
Andrew Gor
Updated at 2025-07-23 14:36:45 UTC
I added the Netro whisperer 2 soil sensor to my ficus pot. The sensor gives me contradictory messages. It says that next watering should be in one week but every night it sends a notification to 'water the ficus sensor's. What should I do?
View: 5401   Answer: 1
Spark not working – won’t start valves despite all attempts
Stefano
Updated at 2025-07-23 06:55:23 UTC
Hi everyone,
I’ve been using a Netro Spark (8-zone model) for some time, but recently it stopped working properly.
The controller connects to Wi-Fi and appears online in the app, but when I try to start any valve (manually or via schedule), it says “communicating” and nothing happens.
  • Restarted the Spark multiple times
  • Performed a full reset (12 seconds on RST button)
  • Re-added the device in the app
  • Tried to trigger irrigation manually from both the app and the controller
  • Confirmed that the system works when I open the valves manually from the controller
  • Tried different power supplies
  • Connected to a mobile hotspot instead of my home Wi-Fi (same result)
  • Updated the firmware to the latest version (v3.3.0)
  • Purchased a brand new Spark controller and tested it — same exact issue
At this point, it looks like the issue is not hardware or network-related.
Could it be a firmware bug or a server-side problem?
Any help would be greatly appreciated!
Thanks in advance,
Stefano Mauri
View: 5618   Answer: 3
Issue with Netro Spark
Fabrice GOUFFRAN
Updated at 2025-07-23 06:34:33 UTC
View: 5408   Answer: 2
Andrew Woods
Updated at 2025-07-22 19:30:55 UTC
View: 5178   Answer: 1
Change zone order
Matt Ward
Updated at 2025-07-22 00:43:18 UTC
View: 7946   Answer: 1
Stefano
Updated at 2025-07-21 21:17:23 UTC
Hi everyone,
I’ve already tried:
Thanks in advance!
– Stefano
View: 7773   Answer: 1
Whisperer low battery alert
Jesus Sanguinetti
Updated at 2025-07-19 15:24:34 UTC
View: 7665   Answer: 1
