Greenhouse
Perry en Louise Mevissen
Updated at 2025-03-22 08:43:22 UTC
One of our sectors runs inside a greenhouse now. Apart from soil type and sprinkler head type, does anyone have advice how to optimise sector settings for this situation? I feel the influence of sun and normal outdoor temperature is different, and rain is completely absent in this sector.
May I suggest to add some sector setting that it is inside a greenhouse?
Perry
View: 9224   Answer: 1
Whisperer availability
Updated at 2025-03-16 18:50:01 UTC
View: 9481   Comment: 1
Tiempo de riego
Doyle Farm
Updated at 2025-03-16 17:30:27 UTC
Gracias Marcelo
View: 7727   Answer: 1
Water transfer during rain
mark spencer
Updated at 2025-03-12 02:34:42 UTC
Is there a way?
View: 7701   Answer: 1
Mike Carey
Updated at 2025-03-02 17:48:24 UTC
View: 8563   Answer: 1
Door came off the unit
Michael Riley
Updated at 2025-02-19 19:52:51 UTC
View: 8373   Answer: 1
Discount
darla
Updated at 2025-01-30 20:05:17 UTC
Darla Carpenter
View: 9103   Answer: 1
W4MSolutions
Updated at 2025-01-23 17:32:49 UTC
View: 8504   Answer: 1
Netro offline
Brett Gardner
Updated at 2025-01-20 00:02:43 UTC
Suggestions?
Hard reset?
Brett
View: 8913   Answer: 1
Pixie - Z1
Steve Inwood
Updated at 2025-01-16 10:10:53 UTC
View: 7837   Answer: 1
Nigel Briggs
Updated at 2025-01-15 10:05:07 UTC
Why ?
View: 11326   Answer: 1
Netro Spark problem
Russ McEvoy
Updated at 2025-01-11 17:12:27 UTC
This morning my 16 zone Spark unit was showing a red LED.
The app said it was online but when I tried to manually water a zone, it just said "connecting" for the duration with nothing happening outside.
Our wifi was running as normal and the room with the controller in had a good signal.
Unplugging and plugging back in solved the problem but it doesn't leave me with much confidence of the unit if it's going to do this at a critical time of year without being noticed.
Is there a reliability issue with the latest firmware?
View: 9893   Answer: 1
Smart Sprinkler Controlle starts then stops
Nigel Briggs
Updated at 2025-01-10 23:15:31 UTC
My controller operates but many times, rather than executing the time setting. It just cuts out?
I do have a sensor connected but I took it out of the ground to exclude wet soil feedback
I'm guessing there is a parameter forcing the stops?
Could anyone give me a direction where to look?
View: 9312   Answer: 1
Fat Cut
Updated at 2024-12-29 07:11:04 UTC
View: 9017   Answer: 1
Zone photo
Russ McEvoy
Updated at 2024-12-28 11:29:31 UTC
Can someone help please?
View: 7909   Answer: 1
Trevor Pfeiffer
Updated at 2024-12-26 20:05:12 UTC
Trevor Pfeiffer
View: 7934   Answer: 1
John BAIMAY
Updated at 2024-12-26 11:35:25 UTC
Regards.
View: 7877   Answer: 1
Random Start
Mario Hardy
Updated at 2024-12-23 12:56:07 UTC
View: 7955   Answer: 1
Reset, but still not connecting
lorenzo s
Updated at 2024-12-19 23:36:08 UTC
Please help. I'll provide a reward for getting my N-12 to work.
lss
View: 10350   Answer: 1
Sprite went offline
dkoford@gmail.com
Updated at 2024-12-18 02:30:29 UTC
View: 9278   Answer: 1
