Zone 1 not watering
11807GFT
Updated at 2024-09-24 23:25:59 UTC
View: 8000   Answer: 1
Updated at 2024-09-19 03:30:21 UTC
View: 39654   Comment: 3
Thomas Murphy
Updated at 2024-09-18 12:39:46 UTC
Hello there!
Thank you so much!
View: 8134   Answer: 1
Sensor
Kathleen Hamilton
Updated at 2024-09-11 19:43:50 UTC
View: 7958   Answer: 1
Smart watering not working
Updated at 2024-09-10 16:17:51 UTC
View: 8168   Answer: 1
Broken whisperer sensor
Jesús López
Updated at 2024-09-09 16:19:33 UTC
Hi everyone!
View: 8939   Answer: 2
Pierluigi Cilli
Updated at 2024-09-08 07:29:59 UTC
View: 8932   Answer: 1
Discrepancia APP y WEB
JM del Amo
Updated at 2024-09-07 13:06:53 UTC
View: 8333   Answer: 1
Tie the irrigation of two lines on the same garden
Francesco
Updated at 2024-09-04 07:59:17 UTC
I have two irrigation lines on the same garden, is there any setting that would allow these two areas to be “tied together” such that they irrigate on the same day (session)? (Obviously first one line and then the other).
View: 9864   Answer: 1
Wunderground
PPL
Updated at 2024-09-02 17:42:25 UTC
View: 7969   Answer: 1
Replace controller
paul.robinson@bigbend.net
Updated at 2024-08-24 22:53:15 UTC
View: 8053   Answer: 1
Ac adaptor
Cisco -
Updated at 2024-08-24 21:45:58 UTC
View: 7820   Answer: 1
problematiche app
Giampaolo Mariani
Updated at 2024-08-20 08:16:25 UTC
View: 7986   Answer: 1
1 valve works, two don't
Phil Rubin
Updated at 2024-08-17 21:52:30 UTC
View: 8465   Answer: 1
Riego
Felipe Martinez Cuadrado
Updated at 2024-08-16 21:16:23 UTC
He instalado el programador y de vez en cuando salta una de las zonas
View: 9556   Answer: 1
Van Klaveren Patrick
Updated at 2024-08-15 10:04:53 UTC
View: 8082   Answer: 1
Smart watering very stupid
Ruth Wengert
Updated at 2024-08-13 14:22:33 UTC
View: 8078   Answer: 1
Terminal 1 not working
Morgans_Home
Updated at 2024-08-12 01:27:03 UTC
View: 7943   Answer: 1
deleting plant sensor
David Ridgwell
Updated at 2024-08-10 01:31:44 UTC
deleting plant sensor??
View: 9562   Answer: 1
2 hub-1 in my house
Troy Guinn
Updated at 2024-08-09 00:15:52 UTC
I have 2 pixe devices and 2 hubs. I have 1 hub and pixie working fine. When I added the 2nd hub it does not show up in the app and therefore cannot add the 2nd pixie what am I doing wrong
View: 9577   Answer: 1
