Zone watering while disabled
Brian Paternostro Paternostro
Updated at 2024-07-31 10:10:11 UTC
I am doing yard work to 2 of my 3 zones right now and have the whole system disabled for several days as many heads are disconnected.  Woke up a 5am to have zone 3 on and spraying water everywhere for 20 minutes.
How is this possible? Why do you not update your softwar?
View: 8823   Answer: 2
Boost factor in app
Jorge Castrillo
Updated at 2024-07-30 13:55:17 UTC
View: 8095   Answer: 1
Sensor plat
Tiago Lourenco
Updated at 2024-07-28 12:17:00 UTC
Good afternoon
I have plant sensors in all zones, and they block.
Sometimes i have my grass really dry and the sensor have 70/80 % of humidity.
I turn them off change place like 2 cm, turn them in again and they have the correct humidity.
Anyone experience this?
Thank you in advance
View: 8513   Answer: 3
Watering system turns on by itself?
Michael Collins
Updated at 2024-07-27 23:34:54 UTC
I have the following odd situations:
1. The Netro does not show any watering activity.
2. My watering system is turning on by itself, and one of my zones is just firing away, spreading water for hours on end.
3. The Netro does not seem to be be able to stop it or even show that it's running.
4. Unplugging the Netro did fix the problem. Even more bizarre
I have an old Netro that never did this. I wonder if I should just swap them out?  This newest one seems to bug sometimes?
Any thoughts what could be doing this?
View: 9702   Answer: 2
Error E1
Simone Ragnolini
Updated at 2024-07-26 11:13:02 UTC
Ho, we need support, as we are having an issue as the app doesn’t activate watering. The control unot shows E1.
View: 8069   Answer: 1
Can't get desired watering time
Fabio Silvestri
Updated at 2024-07-24 19:24:30 UTC
I'm struggling to setup watering time, even after third season im using this app.
As per my settings, EPA suggest to water every day, 30 minutes a day for each zone. The grass is getting sick as all past 2 years, cause the frequency is too high.
I would expect it to water for 1 hour, each 3-4 days. This is what i call "deep watering".
I tried following settings, the frequency decreases, but no way that i can increase the watering time which remains 30 minutes.
Help please
View: 9318   Answer: 1
Connection
jackielaith
Updated at 2024-07-21 04:36:32 UTC
Can't connect to the internet with this app
View: 8981   Answer: 1
La zona non si spegne
Gmultis
Updated at 2024-07-17 16:29:38 UTC
Quando collego la valvola la zona resta alimentata a 24 v anche quando finisce il ciclo. Quindi non smette di irrigare anche con la spia di colore verde.
Senza la valvola invece la tensione torna 0 volt.
Cosa può essere il problema
View: 8224   Answer: 2
Bug in Smart watering Algorithm
texan4ever521
Updated at 2024-07-16 18:53:40 UTC
I would like to know how to get a serious bug in the smart watering algorithm resolved.
I live in north Dallas.  All of our soil is clay.  Most yards (like mine) have Bermuda grass, which is extremely drought tolerant.  This grass grows roots several feet deep and can survive with zero watering for 3 weeks after a downpour that saturates the clay.  (I can show you green grass in a yard that is hard as a rock)  During mid July to mid September the average low is 80 and the high is over 100.  Bermuda grass will go dormant(not dead) if not watered during summer.  You can easily keep the yard looking decent with only 10 minutes of watering per week.
I bought my house in 2020 and it came with a Netro.  After a summer of use, my wife and I failed to look at the auto-pay CC card water bills.  We had accidently spent thousands of dollars on yard watering during the summer. (I can show the water bills)!  (FYI, I had each zone set to the max ECO level)  Instead of buying a new timer, I changed smart-zone to basic instead of advanced and setup very detailed schedules.
My timer got hit by lightning back in May.  I bought a new one and set it up.  I failed to notice that the default value for new zones is "smart zone enabled with advanced setting".  Even though I had set up manual programs the timer found 'loop holes'.  The advanced mode was watering some zones as much as 70 minutes in 1 WEEK!  (compared to previous 10 min a week).  My water bill went from $160 to $400 ( at least I caught it before it got to $800 again).
This bug has literally cost me thousands of dollars with a feature that is supposed to be saving me money.  I am not asking for compensation, it was my mistake that that I failed to look at the schedule and CC auto-pay.
But this bug is ridiculous.
How do we get the following implemented:
1) Global setting for water conservation (impacts all zones) that limits the max per week and max per month that a zone can be watered
2) Budgets inside manual programs that will set limits for max per week and max per month.
3) expand frequency for programs to be across 14 days instead of 7 days
4) notifications from app that informs owner of minutes watered per week and per month.
View: 8062   Answer: 0
Problem with irrigation time
Daniel Encinas
Updated at 2024-07-12 10:43:36 UTC
Hello, I have owned a Netro Sprite programmer for several years.
The problem I have is that it programs the phases intelligently and if it indicates that it has to water for 10 minutes. It only waters for about 1 minute but the app shows that it has watered for 10 minutes. The garden is drying out and I don't know what to do.
This happens to me in all irrigation phases. If I program it manually the same thing happens to me. If I try it twice, the second time it takes even less time to water.
I have connected the transformer directly to the phase, bypassing the programmer, and it works correctly.
Reviewing its problems section, I found a similar one in which it says to look at the 24 volt voltage. (which is correct, around 30 volt) and the resistance in ohms of more than 20 (around 30 ohmios). It also says that there the programmer has a recoverable fuse.
What can I do?
View: 8173   Answer: 1
Manual watering beta
Lynn johnson
Updated at 2024-07-10 04:17:16 UTC
View: 8134   Answer: 1
Cannot find master solenoid valve
kvschlegel
Updated at 2024-07-06 22:46:35 UTC
None of the zones are watering when the app says it's watering. I measured each zone when active and each read 28 AC. When testing the resistance, the readings were jumping all over the place for each reading. This is leading me to believe there is an issue with the master solenoid valve. However, there is no wire that connects to the M slot on the controller. Looking around the house for any of the underground boxes, I have not been able to find the master solenoid. Attaching pictures of what I have found. Any help greatly appreciated.
View: 8453   Answer: 2
2 zones must run the same amount of time
Updated at 2024-07-06 15:35:53 UTC
Hi there
I have the garden zones like the diagram. And I want zone 4 a 3 run the same amount of time. Currently they use different whisperers and have different schedules what makes the grass to present in summer dry patches. I would like to force to run 3 and 4 the same amount of time.
Should I use only one whisperer attached to both zones (3 and 4)?
View: 8846   Answer: 3
Increase Run Time Per Zone
Don Carli
Updated at 2024-07-04 18:58:45 UTC
Don
View: 8444   Answer: 2
Metro timer
Anne McNamara
Updated at 2024-07-04 13:16:31 UTC
Everything shows it should be running, but it doesn’t wake up. I have it set for online during watering periods. It says it’s communicating but it’s not running. How do I wake up metro when I want to communicate
View: 8167   Answer: 1
Red dot
Updated at 2024-07-03 18:53:21 UTC
What is the significance of a red dot next to the green bell ?
Do not see anything anywhere and have not received any notice.
View: 8348   Answer: 1
Steve M
Updated at 2024-06-30 23:53:31 UTC
View: 7979   Answer: 1
Adjusting for tree cover
Steve M
Updated at 2024-06-30 23:47:30 UTC
View: 7934   Answer: 1
all connections good but sprite wont open any valves.
Douglas Ely
Updated at 2024-06-29 11:36:11 UTC
One day, the Sprite just stopped opening the zone valves. We tested and reconnected all the wires and deleted and re-installed the Sprite. Still no luck. Ground is good too. What could be wrong?
View: 8472   Answer: 1
app crashing
Christoforos
Updated at 2024-06-28 14:13:56 UTC
Can you please help.
Christoforos
View: 7951   Answer: 1
