Water time
Wil
Updated at 2024-04-17 04:36:26 UTC
How can I get this to water a certain time.  Like my gardens at 6am?
View: 7656   Answer: 0
Waters too much
Wil
Updated at 2024-04-17 04:34:42 UTC
I inputted my own program. I want it to water the durations I entered.  It doesn't.  How can I turn the so called smart feature off?
View: 7979   Answer: 1
Bob Cohen
Updated at 2024-04-15 23:49:36 UTC
View: 8003   Answer: 2
Firmware updates
Scott Sabo
Updated at 2024-04-13 13:36:52 UTC
Hello, my Netro Sprite shows a firmware version of 1.0.0, assuming that is the initial firmware version. How does this get updated? Searched the web but no resources available. Thanks
View: 8096   Answer: 1
Zone 1 watering everyday
antonio.manso@gmail.com
Updated at 2024-04-13 05:55:10 UTC
I have 9 zones configured, all the same. Zone 1 water everyday while the rest no. How can I fix it? It does not need water everyday
View: 7779   Answer: 1
Zone won't start watering
Homestead One
Updated at 2024-04-11 13:58:33 UTC
For some time one of my zones won't start watering. I have changed the valve with a new one but still won't start watering.
Any ideas? Thank you!
View: 7926   Answer: 1
Exclamation on Schedule
Oilol
Updated at 2024-04-10 12:56:31 UTC
Thanks in Advance!
Tim
View: 7770   Answer: 1
Open Circuit Master Valve
Matt Ward
Updated at 2024-04-08 23:44:05 UTC
My system is not working. When I run a valve test, it shows all valves are normal but the master valve has an open circuit error. I have checked all the wires and there is not voltage at the wires at the valve itself. I used a volt meter at the Netro controller and there is no voltage coming out of the controller for the master valve. Any suggestions?
Matt
View: 8312   Answer: 1
Programs
Roberto Pirovano
Updated at 2024-04-06 16:31:34 UTC
View: 7537   Answer: 0
sensor calibration
Des Mullin
Updated at 2024-04-06 03:36:00 UTC
Hi I have 2 sensors and both read incorrectly. i put both ends into a bucket of water. 1 reads 50% other reads 75% both should red 100%. is there a way to calibrate them.
Update after 2 hrs both reading almost 100%. Do they self calibrate ?
thanks
Des
View: 10199   Answer: 1
weather scheduling
rafal72
Updated at 2024-04-02 21:10:48 UTC
Hi, Weather condition scheduling never worked and I've been using then Netro product for many years now. Currently both forecast & expectation are set at 0.1 threshold with skip (previous day, rainy day and next day). Weather station is set to NetroWeather and main app page is fairly accurate. Just today, it rained for most of the day and NetroWeather showed correctly "100% rain". Sadly, schedule program started anyway even though it was raining. I have changed weather provider, thresholds and nothing changes. This is very annoying to waste water, and I am looking for any tips how to mitigate this issue.
Cheers
Rafal
View: 7874   Answer: 1
2 whisperer to 1 pixie
Paolo S
Updated at 2024-04-02 20:28:39 UTC
View: 8266   Answer: 1
Forecast doesn't show
Edan Manos
Updated at 2024-03-31 05:34:57 UTC
View: 7719   Answer: 1
Potted Pkants
Updated at 2024-03-21 20:24:24 UTC
Wency,
Houston. Texas
View: 8115   Answer: 1
Manual Operation
Mario Hardy
Updated at 2024-03-21 12:47:06 UTC
View: 8052   Answer: 1
Recommend watering schedule
Carolyn Simmons
Updated at 2024-03-17 23:35:07 UTC
We are in zone 9 in Conroe, Texas and would love knowledge on best length of time to water and how often!  Recommendations please!
View: 10308   Answer: 1
Enable button
Steve Llauger
Updated at 2024-03-14 05:11:07 UTC
The enable button does not stay on. It keeps reverting back to unable. Does anyone know why?
View: 7946   Answer: 1
Starting new garden from scratch
Cori
Updated at 2024-03-06 03:16:19 UTC
Hello!
Everything is setup to sow our 170m2 of grass this weekend.
All local gardeners told me to irriigate the planted seeds 5min during the morning and 5min during the night, everyday, however the Netro smart program sets up a weird combination of 10min at 6am then 10 min at 6:40am, and then also for instance 2 days off (each phase, we have 3 for the grass), and this is choosing 'new plant' option.
  Should we leave the Netro smart program or Should we choose our own one???
Thanks!!
View: 10349   Answer: 1
pixie - water inside box and battery housing
veniamin
Updated at 2024-03-02 09:46:44 UTC
Pixie stopped to connect. Removed battery and found water inside battery housing. All contacts except one of battery are very rusty.
Trying to clean. Water also inside battery / battery box
Is it safe to dry and charge?
How to prevent water from entering the box?
View: 8046   Answer: 1
Wifi icon
Carmelo Anaya
Updated at 2024-02-27 10:19:11 UTC
What does this WiFi icon mean?
View: 8176   Answer: 1
