One of my Netro device can’t open the valve.
Bowie Xu
Updated at 2024-05-14 08:55:50 UTC
I connected 3 zones and they were working fine last month. All of the sudden all 3 zones stop to work when I manually run the zones. I tested the voltage using multimeter. It seems the device has no voltage output at all when I run the zone.( I am assuming the correct reading should be about 24V). I tried to unplug/plug to restart the device without any luck. What should I do next?
View: 9410   Answer: 2
PREFERRED ARTICLES
Javier NM
Updated at 2024-05-12 06:36:42 UTC
View: 8269   Answer: 1
SMART WATERING MODES
Javier NM
Updated at 2024-05-12 06:32:07 UTC
Is there an article explaining the different watering modes of smart watering, more that the one line info on the menu? I am looking at information like levels of humidity pursued, depth of watering, or circumstances under which each mode is recommended.  Thank you
View: 8124   Answer: 1
Pixie Z1 Battery Drain
Passawit Kaovilai
Updated at 2024-05-12 03:01:25 UTC
One of my Pixie Z1 is after months of use is having abnormal battery drain where a 100% battery to dead within 3 days. Is this something warranty would cover?
I've replaced 3 sets of AA batteries now within a week or so.
View: 7633   Answer: 1
Antonio Cordon Rodriguez
Updated at 2024-05-08 18:57:57 UTC
Hello.
I have a wishperer sensor in my garden and the measured values, in my opinion, are not correct in the following hours when the garden is watered. I have seen this same problem on other occasions. Is it possible to check it? Thank you very much.
The figure shows an example (the garden is watered at 6am):
View: 7791   Answer: 1
Wafering even when raining
Fabio Silvestri
Updated at 2024-05-07 19:59:22 UTC
I don't understand the logic behind watering after training. Yesterday and today we had heavy Rain, but the Smart schedule plans to start in 9 hours. In the app I also set to stop watering the day before and after Rain, but that seems to have no effect. Temperatures are low as well, i wouldn't expect watering to start before at least 10 days.
View: 8178   Answer: 1
Can’t get water to work
Ally P
Updated at 2024-05-07 18:45:51 UTC
I moved into a house with the Sprite 6 system and have it fully set up on my phone, however can’t get the water to actually run. I haven’t touched anything. Any advice?
View: 9675   Answer: 1
Schedule issue
Barbara Williams
Updated at 2024-05-03 17:43:01 UTC
I have 3 zones. We have had system running for several weeks early in the morning. Yesterday I checked history & found all 3 zones had instead of a green checkmark icon, an orange wifi with red x icon (see photo below). I was able to try "run now", and only zone 1 worked.
I ended up deleting ALL schedules & did a one time water on zones 2 & 3 & they worked. I made a new schedule for all 3 zones, and this morning i got the orange wifi icon on zone 1, & zones 2 & 3 ran just fine.
Any ideas?   TIA!
View: 7967   Answer: 1
ElctroValve don't sart
Francesco Merisio
Updated at 2024-05-02 20:19:07 UTC
Hy, i hava a problem.
When i start a irrigation cycle, only one Valve don't open, but when i start a test cycle from App, the same valve correctly open and start for few second the irrigation.
Why in the ccycke test the same valve it's ok and in the manually start don't go?
Idea?
grazie
View: 7878   Answer: 1
Start external wifi switch
Francesco Merisio
Updated at 2024-05-02 20:15:01 UTC
Hym I have a main pump that start with a wifi switch. Can I call an action from Netro App that start the pump?
For example, whenI start the irrigation cycle, can i call a rest URL?
View: 39019   Answer: 1
Help!
John Zuzula
Updated at 2024-05-02 14:46:09 UTC
View: 7959   Answer: 1
No LED
Derek Barss
Updated at 2024-05-02 04:24:35 UTC
There is no LED on my device.  I've power cycled on and off a few times and no change.
Strangely enough it shows connected to wifi but not starting water on a manual test.
Is it dead?
View: 8121   Answer: 2
Manual operation doesn’t stop
Ciro Bracciante
Updated at 2024-04-29 11:31:14 UTC
View: 7565   Answer: 1
Wifi password reset
Updated at 2024-04-29 06:27:43 UTC
I updated the wifi password in the router. I was able to set up the password in the netro controller but not in the whisperers. I followed the steps provided by the app, pressing 6 times very fast the whisperer button.
But the whisperer wifi did not appear. I tried with 2 of the 5 whisperer I have, but process is not working
View: 10079   Answer: 2
Netro Pixie Z1 Connection Issues to Hub - Please Help
Nicholas Cole
Updated at 2024-04-28 15:58:10 UTC
I have a Netro Pixie Z1 hose timer in my garden, which is about 50 feet away from its hub. I’ve been dealing with connection issues (routinely disconnecting from the app and randomly stopping watering schedules), which is strange because there are no obstructions between the timer and the hub, and it is a fairly short distance. When standing by the timer, I can clearly
see the hub in my window. I have the hub plugged into the back of my WiFi router via an Ethernet cable, so WiFi connection is not the problem. The connection between the timer and the hub is. Does anybody have any suggestions on how to fix this problem? If I can’t get the Pixie Z1 to have a stable connection, I will have to buy a regular Pixie.
- Nick
View: 8020   Answer: 1
App Netro
Updated at 2024-04-28 09:28:48 UTC
View: 7614   Answer: 0
Timer and sensor data incorrect on PC web browser
Mart B
Updated at 2024-04-21 17:25:05 UTC
I had to replace a dead timer a while ago, it and my whisperer are working great in my iPhone Netro app.
But ... when I log into my Netro home on a PC, using MS Edge web browser, my current equipment is not there, it has all my old stuff that should no longer exist ... I checked and am definitely logging in as the same account on both iOS and PC. It is very weird.
Is there any way to get this corrected?
View: 7738   Answer: 1
Fabio F
Updated at 2024-04-20 14:28:45 UTC
 How do I solve this problem?
View: 8425   Answer: 4
Whisperer 2 problems
Bruno
Updated at 2024-04-17 20:54:19 UTC
As you can see the humidity sensor give some strange readings...
How can change those values in such way without touching the sensor or watering. I'm scared of the reliability of such things...
View: 8360   Answer: 1
Skip watering did not work
Updated at 2024-04-17 12:50:29 UTC
I have the whisperer to avoid watering over 40% humidity, but the system did not skip it
View: 8051   Answer: 1
