Good results
R C
Updated at 2023-10-24 18:55:29 UTC
View: 12845   Comment: 2
The app is full of useless things
MB
Updated at 2023-10-19 17:08:43 UTC
MAKE IT SIMPLE AND FAST!
- not possible to run multiple valve at the same time
- app and webapp full of useless things such as the BIG clock in the schedule attached
- interface full of too many things. I dont care about smart watering. why my screen should be full of that?
- setting full of useless things.
- apps should be fast and simple, if you focus on professionals. If you focus on housewives is another story.
- example of ewelink
- not possible to run all the time you want. max 60 minutes. Edit program full of things again.
- under zone there should be the possibility to add the schedule. why you are making an extra menu?? Zone 1 --> prog1 -->start h8.00; finish h.10:00
View: 8622   Answer: 1
Terrible product?
Andrew Martin
Updated at 2023-10-16 14:26:31 UTC
Three hours to setup
View: 8643   Answer: 2
Sprite 12 Controller Problem
John LaRocca
Updated at 2023-10-14 01:42:23 UTC
View: 8279   Answer: 1
Alexa Skill
Louise Brinkman
Updated at 2023-10-13 01:00:17 UTC
View: 9728   Comment: 3
Whisperer maintenance
Fabrice GOUFFRAN
Updated at 2023-10-11 02:34:36 UTC
View: 7146   Answer: 1
Zone failure to run
Homestead One
Updated at 2023-10-09 08:30:37 UTC
Hi, I have one out of 4 zones who won't start watering. I have changed the valve and the problem still persist. I have checked the connections and the cables, all looks good. There is voltage.
Any ideea?
View: 7698   Answer: 1
Hub with more than 1 timers
Kay Fluhr
Updated at 2023-10-08 07:46:18 UTC
Dear netro team
I solved the problem.
View: 8431   Answer: 1
Yellow exclamation mark
MyGowdy
Updated at 2023-10-07 23:05:24 UTC
View: 8417   Answer: 1
Linking Google Home to Netro
cadry1969
Updated at 2023-10-07 03:21:23 UTC
View: 8402   Answer: 2
Zone Failure
Ben Pittarelli
Updated at 2023-10-03 12:31:07 UTC
I have the Sprite 12 controller with zone 3 failing to work after 10 months.  Traced error to low voltage on controller. Anyone else having zone failures caused by controller?
Moved wire to unused zone 12 and sprinklers engage as they should.
View: 8502   Answer: 1
2 zonas funcionando a la vez?
Juan Carlos
Updated at 2023-09-30 18:53:13 UTC
View: 8657   Answer: 1
Phil Middleton
Updated at 2023-09-30 12:48:53 UTC
Kind regards
Phil
View: 8805   Answer: 1
Whisperer 2 "serial already in used" issue
pridebowl33
Updated at 2023-09-29 16:07:36 UTC
I have been trying to add back one of my Whisperer 2 sensor and got a message saying that the serial has been already in used. Not sure what to do at this point. I was wondering if someone had encountered the same issue and if there is a solution to fix it.
Kevin
View: 8455   Answer: 1
kamiller42
Updated at 2023-09-29 15:44:58 UTC
View: 8165   Answer: 1
Schedule
Jim Lacy
Updated at 2023-09-28 02:00:48 UTC
View: 8650   Answer: 1
Horario
Conchi Herrero
Updated at 2023-09-27 13:00:48 UTC
Gracias.
View: 8278   Answer: 1
Unrequested watering cycle
Claudio Polacco
Updated at 2023-09-23 07:00:27 UTC
Hello everybody, maybe someone can help.
This morning I found the irrigation system on, watering the garden, with no schedule active. More, the master enable/disable switch on the app homepage was set to off.
I'm using manual zone scheduling, not smart watering.
The controller is a Netro Sprite 6 zones, Wifi was on and fully functional.
Any ideas? Thanks.
Claudio
View: 8520   Answer: 1
Stephen CC
Updated at 2023-09-19 08:44:03 UTC
View: 8314   Answer: 1
Copy setting to new spark device
John Wright
Updated at 2023-09-17 19:57:29 UTC
My original netro spark died and I have received a new one.  Is there a way to copy the zone settings from the old to the new
View: 10928   Answer: 1
