sellet
Updated at 2023-07-13 16:20:23 UTC
View: 8399   Answer: 1
Random Manual Start
Mario Hardy
Updated at 2023-07-13 04:53:04 UTC
How to make this stop???
View: 8738   Answer: 1
Random Manual Start
Mario Hardy
Updated at 2023-07-13 04:52:51 UTC
View: 8353   Answer: 0
Warranty
BOBBY BROWNE
Updated at 2023-07-11 17:32:17 UTC
View: 8388   Answer: 1
Updated at 2023-07-11 12:26:26 UTC
View: 8991   Answer: 1
Restrictions
Mark Killeen
Updated at 2023-07-10 22:48:36 UTC
View: 8771   Answer: 1
Restrictions
Mark Killeen
Updated at 2023-07-10 22:48:23 UTC
View: 8671   Answer: 0
Why no cycle soak setting?
Updated at 2023-07-08 19:56:33 UTC
View: 8800   Answer: 1
Pixie Z1
ke7vng
Updated at 2023-07-08 02:25:00 UTC
View: 8013   Answer: 1
Moisture and weather API
Andrea D.
Updated at 2023-07-07 23:20:33 UTC
Hello there,
View: 8502   Answer: 2
Bruno
Updated at 2023-07-07 22:09:44 UTC
View: 8836   Answer: 1
John Zuzula
Updated at 2023-07-06 22:57:53 UTC
View: 8702   Answer: 2
Michael Burberry
Updated at 2023-07-05 22:39:33 UTC
View: 8251   Answer: 1
Can't reconnect wifi
Yuriy Andamasov
Updated at 2023-07-05 21:14:40 UTC
sprite-6 went offline
never pass step 5
worked just fine almost year
View: 8537   Answer: 1
LOAD ISSUE NOTIFICATION
Javier NM
Updated at 2023-07-04 11:25:43 UTC
View: 8867   Answer: 1
Not enough watering
Manuel Herbst
Updated at 2023-07-03 20:19:28 UTC
Hey everybody,
Can anybody help me?
Manuel
View: 8587   Answer: 1
Cambio días de demora.
Lino
Updated at 2023-07-03 06:35:04 UTC
View: 8270   Answer: 2
Moisture level
Updated at 2023-07-03 00:49:48 UTC
Rained hatd in my area but the moisture level is still in the teen, is there a way I can change my zones to 100% moisture?
View: 9534   Answer: 1
Spanish translation problem
Abraio
Updated at 2023-07-02 20:49:46 UTC
Greetings from Spain.
View: 8266   Answer: 1
Previsioni meteo sbagliate
Manuel Mancini
Updated at 2023-07-01 15:59:30 UTC
View: 8206   Answer: 2
