A Netro Spark with no WIFI
Lino
Updated at 2023-05-25 16:07:02 UTC
Just bought a Spark and realized my home wifi sig doesn’t reach the location where it is installed.
While I sort out how to increase the signal I wonder if there is a way to program the Spark to operate without Wifi
View: 7988   Answer: 1
Netro Spark firmware version
Luis T
Updated at 2023-05-24 15:54:35 UTC
I have a Netro Spark with firmware version 3.2.1. Firmware updates are done without user intervention or how can I perform a firmware update?
View: 8623   Answer: 1
Update the irrigation routine according to the updated weather forecast
Luis T
Updated at 2023-05-24 15:44:31 UTC
Hi there!
I live in Madrid, Spain and use AccuWeather as my weather provider, since NetroWeather does not provide a correct forecast for this area for some reason.
This week we have had heavy rain forecast so Netro will not activate the irrigation system for several days. The problem is that as the day goes by the forecast is changing and Netro's planning is not updated.
It has already been several days in which according to the initial forecast, it was supposed to rain and it did not, so I have had to launch manual irrigations.
Is there any way to force the smart irrigation program to update according to the new weather forecast?
View: 8723   Answer: 1
Frequently disconnection from the wifi
PaoloMassignan
Updated at 2023-05-24 05:07:48 UTC
My device is always offline unable to connect to the wifi. I have to reset it and then the connection works for a while.
There is a repeater  2 meters from it. The signal is strong.
View: 7850   Answer: 1
Cannot connect
Jerry Gadd
Updated at 2023-05-23 19:15:35 UTC
I am not able to successfully connect to my new pixie
1. Pixie lifht flashing white
2. Login to App
3. Add Product
4. Select device
5. Enter name and addess info
6. Begin
7. Connext phone to Netro wifi
8. Next
9. Select homw wifi
10. Enter password
11 next
... Connecting...
Pixie light flashes white, eventually turns red
App errors
Wifi password is correct, and i am in same room as router aand pixie is next to me.
How dobi check port is not beinf blocked hy router? I have Huaweu Q2 Pro, dont see anything tonsuggest iit is.
View: 10771   Answer: 1
Material
Georges Bouvier
Updated at 2023-05-23 07:32:12 UTC
Does Netro supply an equipment with 2 output
I need watering 2 different areas?
Thks
View: 10294   Answer: 2
Strange watering cycle
Joe Mariano
Updated at 2023-05-22 14:40:16 UTC
View: 8068   Answer: 1
Mismatch zones/times
Jose R
Updated at 2023-05-21 12:40:53 UTC
So happy with how this works.
View: 7742   Answer: 1
App Showing Ofline
Katie Wallace
Updated at 2023-05-21 11:09:21 UTC
View: 7596   Answer: 1
Watering problem
Marco Nicosia
Updated at 2023-05-21 10:35:08 UTC
Does it happen to anyone that sometimes the irrigation starts by itself despite the program being set to manual?
View: 7710   Answer: 1
Problem in Netro app in my iPhone
Manel Barbero
Updated at 2023-05-18 08:21:17 UTC
I had installed an irrigation controller and one plant sensor and it worked OK. Since I have added one Pixie-1 and one Pixie-Z1, on the app screen when I try to enter innthe red ring bell to see notifications, I am thrown out the app and I can’t see my notifications.
View: 8332   Answer: 1
Richard Nibbler
Updated at 2023-05-17 02:50:09 UTC
Tyvm
View: 8462   Answer: 3
Days not appearing on 6-days a week schedule
Rec Tift
Updated at 2023-05-17 02:40:49 UTC
Our watering restrictions are on 6-days a week. Thursday, Friday, and Saturday do not show water schedule. How do I add these days to program?
View: 8004   Answer: 1
Whisperer wifi connection
Jim Shields
Updated at 2023-05-15 21:20:33 UTC
View: 7798   Answer: 1
Updated at 2023-05-14 12:23:35 UTC
Kirk
View: 8515   Answer: 1
S R
Updated at 2023-05-13 00:02:22 UTC
View: 12524   Answer: 2
Paolo S
Updated at 2023-05-12 15:41:24 UTC
Any suggestion?
Any issue with iphone 14?
View: 8199   Answer: 1
Nitro speak to system
Charlie Patel
Updated at 2023-05-11 18:55:33 UTC
View: 7665   Answer: 1
Anupam Kumar
Updated at 2023-05-11 00:29:18 UTC
View: 7650   Answer: 1
Bruno
Updated at 2023-05-10 22:41:29 UTC
View: 8390   Answer: 1
