Smart zone manual setup
Vieri Verze
Updated at 2023-02-18 08:31:43 UTC
I do not understand how many millimeters to set. I have microsprinklers of 4lt/h and 2lt/h. I thought to set to 4000ml/h but the max is 100ml/h.
How to calculate? I have a big terrace with 30 plants and various microsprinklers.
Vieri
View: 8508   Answer: 2
Richard
Updated at 2023-02-17 06:29:52 UTC
Hi there.
Cheers.
View: 8710   Answer: 2
Set watering days
Mel Culley
Updated at 2023-02-12 02:31:35 UTC
I am struggling to set up the watering days
There isn’t an option for 4 / 3 / 4 rostered days which is are allocation here in Perth Australia
Please advise
TIA 👍
View: 11295   Answer: 2
Whispered sola panel deteriorated after 6 months
Updated at 2023-02-08 06:15:54 UTC
After 6 months of whispere’s exposed to sun, the protective layer of screen is started yo be deteriorated, losing the transparency property and protection to UV, meaning is catching up less sun.
Answer from Netro support after several exchanges had not been at the right level, despite that last topic was really well addressed.
“Thanks for your info and it should not affect the normal use of the sensor. Please let us know if you see any further issues during use.“
Check pictures and make your statement, but I am not convince about quality of manufacturing of the whispered elements.
David
View: 8639   Answer: 1
Smart schedules
Vincent Coutinho
Updated at 2023-02-07 20:51:01 UTC
View: 8522   Answer: 1
Vanina Lesko
Updated at 2023-02-03 09:47:24 UTC
View: 8387   Answer: 1
MEANING OF code E2
balvant patel
Updated at 2023-02-02 16:06:49 UTC
What is E2 means?
Pl. reply ASAP
Patel
View: 8139   Answer: 1
Whisperer light
Updated at 2023-02-01 09:56:18 UTC
What should I do ?
View: 8582   Answer: 1
Help
Vũ Trần
Updated at 2023-01-30 07:35:09 UTC
View: 9959   Answer: 3
Whisperer plant sensor
Vincent Coutinho
Updated at 2023-01-26 20:56:14 UTC
How do you find the sensor battery percentage on the netro app.
View: 8554   Answer: 1
Jim Barnes
Updated at 2023-01-25 13:36:55 UTC
Please help!!!
View: 8411   Answer: 2
andrew58
Updated at 2023-01-25 08:49:48 UTC
View: 7803   Answer: 1
Reduce watering time in 1 zone
Ale Levi
Updated at 2023-01-22 19:32:59 UTC
Hi, I'd like to reduce the watering time in 1 zone which gets dumped each time Netro waters. The other zones are ok. Is there a way to do that in the smart mode? Maybe set an offset for that specific zone?
View: 7822   Answer: 2
Delay on Manual watering
Jim Barnes
Updated at 2023-01-22 01:22:58 UTC
Why is it when I select a manual watering it delays until wake up?
View: 8294   Answer: 1
Change Username
Casa Luna
Updated at 2023-01-13 10:08:35 UTC
Is it possible?
Thanks in advance :)
View: 7723   Answer: 1
Customized moisture level not triggering watering
Richard
Updated at 2023-01-12 21:29:59 UTC
I have a Sprite with 3 Whisperers, all in the veggie patch.
I have the zones set to customize with a low of 25% and a high of 45% (I find 30 - 35 % moisture about right)
But the zones just won't get watered!
Zone 1 is down to 6% today and has been dropping steadily for days.
I HAVE to manually water, as the day time temperatures are consistently over 30 degrees (today 33, tomorrow 37).
Otherwise the plants will die.
Given there are only two values to enter (low and high). How do I stop the Netro from skipping days and putting the zones in the "Moisture" category??
View: 9796   Answer: 1
Home Assistant
Jens Wymeersch
Updated at 2023-01-12 09:25:04 UTC
View: 9733   Answer: 2
Green Peas
Updated at 2023-01-01 18:34:14 UTC
View: 8383   Answer: 2
Andrew
Updated at 2022-12-29 21:38:22 UTC
View: 8432   Answer: 3
Updated at 2022-12-26 09:03:17 UTC
View: 8596   Answer: 1
