Not watering
jons
Updated at 2022-09-16 09:37:00 UTC
It shows watering, but it is not?
View: 8250   Answer: 1
Different symbols in the app
Leon Durning
Updated at 2022-09-13 16:05:13 UTC
What does the ! mean?
View: 8425   Answer: 1
Mulch impact on duration
John Wright
Updated at 2022-09-13 12:58:29 UTC
View: 8411   Answer: 1
Kickstart the Netro Zigbee Hub and Pixie-Z1
Updated at 2022-09-13 06:23:11 UTC
To the Netro community:
We are excited to introduce our new products, the Netro Zigbee Hub and the new smart timer Pixie-Z1. They combined deliver a different experience of smart watering system.
The Netro Zigbee Hub hosts a long-range local Zigbee network that links all the end devices. It connects to your router (wireless or wired) to transfer data between the end devices and the Netro cloud service. The Hub will work with all our Zigbee products including the new timer Pixie-Z1(introduced below) and the new soil moisture sensor coming this year, as well as the new 4-Zone sprinkler controller and the new weather sensor coming next year.
The new host timer Pixie-Z1 is re-designed from the original Pixie timer in many ways:
1. Always online for instant quick runs. No more sleep mode
2. Powered by two AA alkaline batteries with approximately one year of battery life. Notifications on low battery
3. Supports Google Home and Google Assistant
The Netro Zigbee Hub and Pixie-Z1 are expected to ship in September. To join the Tester program please email to info@netrohome.com and we will send you a discount code in return for feedbacks.
View: 137156   Comment: 3
quick stop every watering
Lee Hill
Updated at 2022-09-11 20:34:04 UTC
View: 7378   Answer: 1
Cannot reset Sprite
punyelroo
Updated at 2022-09-10 22:30:01 UTC
How do I fix this ?
-A
View: 8638   Answer: 1
Add a manager
Tom Warren
Updated at 2022-09-10 16:36:08 UTC
View: 8321   Answer: 2
Updated at 2022-09-10 12:26:33 UTC
View: 8913   Answer: 1
Updated at 2022-09-07 21:08:59 UTC
View: 8793   Answer: 1
Updated at 2022-09-07 05:47:06 UTC
May you check it?
View: 7736   Answer: 1
Updated at 2022-09-05 21:41:34 UTC
KVACHEST132
View: 7690   Answer: 1
Karen Thompson
Updated at 2022-09-02 15:15:20 UTC
View: 8824   Answer: 1
Two zones running at the same time
Jesse Sanchez
Updated at 2022-09-02 03:52:13 UTC
Anyone running into an issue of having two zones run at the same time when doing a manual run?
View: 8232   Answer: 1
How many rain sensors?
Roland Pircher
Updated at 2022-09-01 17:53:32 UTC
View: 8127   Answer: 1
Help! Pump Relay Question
Updated at 2022-09-01 13:43:25 UTC
My unit has been working great . However, the relay no longer trips when a zone is activated. Am I supposed to have 24v A/C between M and C (on the right side of the panel, not the zone side) when a zone is active? I can trip the relay if I pull it from the Netro. Some sort of voltage output map would be helpful.
I have new grass seed down, so please help soon.
View: 10243   Answer: 1
Random sprinklers turn on
Brian Strickler
Updated at 2022-09-01 12:33:12 UTC
View: 7468   Answer: 2
Program
Bob Neal
Updated at 2022-08-31 17:11:55 UTC
View: 6964   Answer: 1
IFTTT out of sync
Updated at 2022-08-30 07:08:46 UTC
Please advise.
View: 9076   Answer: 2
A Gallo
Updated at 2022-08-29 14:28:38 UTC
View: 8423   Answer: 1
Error in watering ?
Davide M.
Updated at 2022-08-29 11:31:56 UTC
Please help me:
  1.  what should I trust ?
APP:
WEB:
View: 8837   Answer: 1
