scottsleight
Updated at 2022-08-08 21:41:10 UTC
View: 8843   Answer: 1
Jeff Davidson
Updated at 2022-08-07 22:23:56 UTC
View: 6443   Answer: 1
Weather Station
Rob Dog
Updated at 2022-08-07 08:21:44 UTC
Thankyou
View: 6423   Answer: 1
Intelligent watering plan
Gregor Schuller
Updated at 2022-08-06 17:43:10 UTC
View: 8300   Answer: 1
WU Station Request
Richard B
Updated at 2022-08-06 14:17:21 UTC
View: 7949   Answer: 1
Second plug had broken
Updated at 2022-08-06 12:38:41 UTC
View: 7052   Answer: 1
Optimum moisture level
Spiros Koutmos
Updated at 2022-08-06 06:35:33 UTC
View: 6483   Answer: 1
Offline
Kevin Naylor
Updated at 2022-08-05 14:39:53 UTC
View: 6538   Answer: 1
Rain
Rob Nelson
Updated at 2022-08-05 11:08:18 UTC
View: 6830   Answer: 1
Gregor Schuller
Updated at 2022-08-05 07:45:41 UTC
View: 8563   Answer: 1
Water Saving Results
prichmond
Updated at 2022-08-04 22:54:11 UTC
View: 8007   Answer: 1
Weather Underground
Updated at 2022-08-03 13:52:50 UTC
Much appreciated
Kirk
View: 7391   Answer: 1
Dark mode/ font update?
Updated at 2022-08-03 13:48:59 UTC
View: 7432   Answer: 1
Douglas Ely
Updated at 2022-08-02 10:30:54 UTC
View: 9066   Answer: 1
Consistently underwatering
Douglas Ely
Updated at 2022-08-02 10:14:34 UTC
View: 9105   Answer: 1
Severe water restrictions
Michael Wheatley
Updated at 2022-07-31 02:18:20 UTC
View: 7112   Answer: 1
Offline
Francesco V
Updated at 2022-07-30 22:01:37 UTC
View: 6916   Answer: 1
Wrong scheduling?
Carlos Jimeno
Updated at 2022-07-30 07:49:09 UTC
Any ideas to solve it?.
Thank you very much.
View: 8216   Answer: 1
Whispered wrong temperature range?
Updated at 2022-07-29 17:51:27 UTC
I had just installed 3 whisper and two of them are showing temperature o 3xxx °C, while the third one is correct.
Is this normal? Or will be auto updated?
View: 9228   Answer: 2
Alex Heath
Updated at 2022-07-28 17:46:04 UTC
View: 7798   Answer: 1
