App locks up
Updated at 2022-08-29 08:39:41 UTC
Please advise.
View: 8831   Answer: 1
Manual watering
Hadeel Hammodat
Updated at 2022-08-29 02:22:09 UTC
View: 8123   Answer: 1
Soil
Stephen Brewer
Updated at 2022-08-27 12:11:15 UTC
Many thanks in advance
View: 11435   Answer: 1
Wunderground
Brian Strickler
Updated at 2022-08-25 16:43:35 UTC
How can I get station id
KMTJOLIE28
Added to my controller
View: 7211   Answer: 1
rbrodt
Updated at 2022-08-25 16:29:00 UTC
View: 8451   Answer: 1
Suspect a shorted solenoid
rbrodt
Updated at 2022-08-25 16:00:32 UTC
I bought a Netro Spark to replace an existing controller (a Raspberry pi based Open Sprinkler system) which exploded probably due to a shorted solenoid.
I read that the Spark can detect solenoids that are drawing too much current; is it safe to connect the Spark to shorted solenoids without worrying about damage to the controller?
Should I test all the solenoids with an amp meter first just to make sure?
View: 9117   Answer: 1
How can add zones
Veronica Slaughter
Updated at 2022-08-25 04:20:46 UTC
View: 7126   Answer: 1
texan4ever521
Updated at 2022-08-24 20:24:11 UTC
My settings :
soil type: clay
sprinkler type: rotor head
shade: none or some shade
View: 8606   Answer: 1
Clock on sprite
Rory
Updated at 2022-08-24 19:43:30 UTC
View: 8113   Answer: 1
Kasper Huber
Updated at 2022-08-24 13:15:29 UTC
View: 8249   Answer: 1
Can Pixie measure water flow?
Updated at 2022-08-23 14:09:01 UTC
View: 8633   Answer: 1
Updated at 2022-08-21 09:13:22 UTC
View: 8674   Answer: 1
Total reset
Azrandy
Updated at 2022-08-20 17:23:56 UTC
How do you do a total reset?
Seamed to be stuck ?
View: 6866   Answer: 1
Whisperer too weak
Updated at 2022-08-19 21:10:55 UTC
Hi there
View: 8852   Answer: 1
Updated at 2022-08-19 20:49:40 UTC
Wency,
View: 7559   Answer: 1
Why gap in smart schedule?
Updated at 2022-08-19 00:35:41 UTC
View: 8743   Answer: 1
Updated at 2022-08-19 00:34:04 UTC
View: 8684   Answer: 1
How to remove rain delay
Gyanendra Kumar
Updated at 2022-08-18 19:35:45 UTC
View: 11358   Answer: 1
Valeria Dp
Updated at 2022-08-18 10:11:54 UTC
View: 8186   Answer: 1
Update Feature
Updated at 2022-08-17 16:09:34 UTC
Alfonso
View: 8865   Answer: 1
