Pixie water pressure
Chris
Updated at 2022-07-15 09:03:05 UTC
View: 7844   Answer: 1
Waters excessively
Cindy Luvender
Updated at 2022-07-14 16:38:38 UTC
View: 8301   Answer: 1
Plant sensor
Miro D
Updated at 2022-07-14 10:42:35 UTC
View: 7936   Answer: 1
More data
Jim Shaffer
Updated at 2022-07-13 13:06:30 UTC
View: 7956   Answer: 1
Netro connection to IFTTT
Sarah Kottke
Updated at 2022-07-12 13:44:09 UTC
Anyone had luck?
Sarah
View: 8137   Answer: 1
Android devices logout issue
Wency Pan
Updated at 2022-07-12 06:35:45 UTC
View: 12549   Comment: 1
Day view
Updated at 2022-07-12 04:10:37 UTC
View: 8073   Answer: 1
Updated at 2022-07-10 11:25:02 UTC
View: 8204   Answer: 1
Power device heat
David Domingues
Updated at 2022-07-09 17:15:45 UTC
Hello all,
I just bought a Netro controller with only 2 areas setup and I like it so far.
I was wondering if the noise and heat from the power supply was a  normal thing to happen.
Thanks in advance.
View: 8844   Answer: 2
Want to use two controllers
dl74pw@yahoo.com
Updated at 2022-07-09 14:19:31 UTC
View: 6196   Answer: 1
WU weather provider question
Weston Hull
Updated at 2022-07-09 01:43:02 UTC
View: 7798   Answer: 1
Frank Fang
Updated at 2022-07-08 18:44:28 UTC
View: 6285   Answer: 1
Zones cut out
tbbucans
Updated at 2022-07-08 00:44:31 UTC
View: 6217   Answer: 1
Smart watering settings
SK Breuer
Updated at 2022-07-07 17:34:52 UTC
View: 7720   Answer: 1
Manual runs overriding schedule
unislock
Updated at 2022-07-07 12:02:15 UTC
Is there a way to not have manual runs conflict with the smart schedule?  At times I turn sprinklers on for kids to have fun or to test a newly installed head for a few minutes. These manual runs (even for a minute or two) in these zones are not being run during the next scheduled run. This is frustrating and now I need to do a lot of manual runs to ensure lawn gets appropriate amount of water and is basically taking away my ability to auto schedule.
Thoughts?
View: 8588   Answer: 2
Laks
Updated at 2022-07-06 13:33:47 UTC
thank you
View: 7713   Answer: 1
Home51
Updated at 2022-07-05 20:23:39 UTC
Zev
View: 7412   Answer: 1
eater flow meter
Corneliu PINTILIE
Updated at 2022-07-05 14:11:11 UTC
View: 7626   Answer: 1
Rain presiction is wrong
Paul X
Updated at 2022-07-04 15:12:41 UTC
View: 12020   Comment: 1
Login Error: Can't find user
Patbouvry
Updated at 2022-07-04 01:08:57 UTC
Pat.
View: 7002   Answer: 1
