Why is there no on/off
Eric Berndt
Updated at 2022-06-01 19:01:43 UTC
View: 7500   Answer: 2
Zone
Bertin Grégory
Updated at 2022-05-31 15:50:10 UTC
Bonjour
Serait-il possible d’activer 2 zones en même temps réfléchi
View: 9712   Answer: 2
Andy Ricco
Updated at 2022-05-31 06:12:27 UTC
View: 8871   Answer: 1
Setting up the schedule
Sasha Obradovic
Updated at 2022-05-30 22:11:58 UTC
I’m trying to setup schedule for watering for next five months, But watering schedule shows only for two next months. I check the settings and I do have a selected five next month. is there something I’m not doing right?
View: 8882   Answer: 2
Ron
Ron Ferrars
Updated at 2022-05-30 14:12:27 UTC
View: 12214   Comment: 1
Schedule screen
Dick Milde
Updated at 2022-05-30 14:02:03 UTC
View: 6475   Answer: 1
Schedule is empty?
Jacopo De Simoi
Updated at 2022-05-29 02:44:51 UTC
Best
 Jacopo
View: 6753   Answer: 1
Netro screwed up
Jack Davis
Updated at 2022-05-28 16:14:25 UTC
View: 7300   Answer: 1
Connection issues
Ant Va
Updated at 2022-05-27 09:57:09 UTC
View: 7444   Answer: 3
milanese
Updated at 2022-05-27 02:32:57 UTC
iPhone -
- Get app
- Crete account
- Go to connect timer
- Next
- Enter name and stuff, next
- Turn on unit, next
Please advise.
View: 8115   Answer: 1
Discover irrigation
Updated at 2022-05-25 06:52:34 UTC
View: 7144   Answer: 1
Pixie wifi connection
Luis Borrás
Updated at 2022-05-25 05:58:44 UTC
Luis
View: 6561   Answer: 1
Wayne Smith
Updated at 2022-05-24 20:51:31 UTC
View: 6673   Answer: 1
Bayoule Bayoule
Updated at 2022-05-24 18:50:51 UTC
JM
View: 8094   Answer: 2
Night watering
John Kot
Updated at 2022-05-23 21:15:34 UTC
View: 8254   Answer: 1
Meteo app
Enrico Marion
Updated at 2022-05-23 17:03:37 UTC
View: 6771   Answer: 1
Updated at 2022-05-23 14:33:07 UTC
View: 10991   Answer: 1
MQTT port is blocked
Jose Juan Dios
Updated at 2022-05-22 11:51:44 UTC
Can you help me please?
Thankyou
View: 8140   Answer: 1
malfunction
Ramón Sellés
Updated at 2022-05-22 10:28:57 UTC
volume_up
content_copy
share
View: 6767   Answer: 1
Updated at 2022-05-21 17:31:03 UTC
View: 7633   Answer: 1
