Gaspare Miceli
Updated at 2022-04-18 06:23:55 UTC
View: 11220   Answer: 1
Feature Request
Tod Johnson
Updated at 2022-04-16 18:22:20 UTC
View: 6524   Answer: 1
Watering days
Updated at 2022-04-16 18:22:19 UTC
Home display is correct and shows Last watering the day before at the date and time in the program (watering planned everyday) but under Discover many days are shown as if there has not been any irrigation.
What could be the reason why ?
View: 8917   Answer: 2
idpitt
Updated at 2022-04-16 13:50:17 UTC
What am I missing?
View: 7229   Answer: 1
Scott Gustafson
Updated at 2022-04-14 22:26:18 UTC
View: 8838   Answer: 1
App crash
Jiang Zheyue
Updated at 2022-04-14 14:34:05 UTC
View: 7267   Answer: 1
Dsohunter
Updated at 2022-04-13 14:39:27 UTC
View: 8258   Answer: 2
Localization
JM del Amo
Updated at 2022-04-12 10:19:03 UTC
View: 8945   Answer: 1
Parts for Pixie
Robert Squires
Updated at 2022-04-11 14:11:50 UTC
View: 8167   Answer: 2
Like the app update.
Dave Henderson
Updated at 2022-04-09 02:14:47 UTC
View: 72969   Comment: 3
Mike Ahlmann
Updated at 2022-04-06 18:41:13 UTC
View: 7345   Answer: 1
Completely lost
jnk0
Updated at 2022-04-06 04:01:09 UTC
View: 7018   Answer: 1
Smaller time limits
Rocky Hill
Updated at 2022-04-05 23:28:18 UTC
View: 7400   Answer: 1
Maureen Horan
Updated at 2022-04-05 17:22:11 UTC
How do I add a zone
View: 6612   Answer: 1
manual app do not work
Updated at 2022-04-05 14:07:41 UTC
hi
no push button
View: 7326   Answer: 2
app / manual
Updated at 2022-04-05 14:03:37 UTC
View: 7201   Answer: 1
idpitt
Updated at 2022-04-03 14:58:04 UTC
View: 8960   Answer: 1
Pixie problem
Luis Borrás
Updated at 2022-04-03 10:22:59 UTC
View: 8172   Answer: 1
Dark Sky Weather
Martin K
Updated at 2022-04-01 19:51:52 UTC
View: 7002   Answer: 2
Addind new pixie
jesusvenegas
Updated at 2022-03-29 13:10:04 UTC
View: 6263   Answer: 1
