Gabriele Cofano
Updated at 2022-03-02 12:45:59 UTC
View: 8220   Answer: 1
Interface
John Degolyer
Updated at 2022-03-02 05:58:45 UTC
View: 9106   Answer: 2
Wifi issues
Anthony Bowersox
Updated at 2022-02-27 22:11:24 UTC
View: 6503   Answer: 1
Meteo
Rob Rossi
Updated at 2022-02-25 13:46:37 UTC
How can i solve?
Thanks very much
View: 6918   Answer: 2
Netro Spark
ELBOUHSSAINI larbi
Updated at 2022-02-25 12:22:22 UTC
View: 6536   Answer: 1
future user of your device
ELBOUHSSAINI larbi
Updated at 2022-02-24 22:49:40 UTC
currently I have a rain bird 4 station device without wifi which gives me satisfaction but unfortunately without wifi zpres research on the internet your device interests me and I want to have some explanation
 - does the device work and trigger the irrigation program in case of wifi failure
 -Does the device back up program data in the event of a power outage?
 - does the humidity sensor come with the device i no where can i buy it
View: 8025   Answer: 1
Netro Sprite 6 no enciende la bomba
Vanina Lesko
Updated at 2022-02-20 12:24:48 UTC
Hicimos la instalación tal como figura el manual pero ni las electroválvulas ni la bomba de agua enciende cuando programó el riego. La app dice q está regando pero no funciona el riego.
View: 9461   Answer: 2
Duane Smith
Updated at 2022-02-16 21:58:22 UTC
Good Afternoon Everyone,
Duane
View: 8398   Answer: 1
whisperer off almost 1 month
Updated at 2022-02-16 17:01:49 UTC
seems that whisperer didnt collect data for almost one month!!, this is due to battery? we are in winter but it’s installed on a sunny place!! and app did no send alerts when this happens!!?
View: 8948   Answer: 1
Netro Whisperer Nuevo 2 dias y no enciende…
Quim Retbin
Updated at 2022-02-14 20:51:24 UTC
Hola, compre el Netro whisperer y con 2 dias al menos 4 h al sol y siempre la luz roja es normal esto?
Pone que 1h es 2 a 3 dias y aun no ha encendido ningun dis y tampoco lo he podido configurar ni nada.
View: 9119   Answer: 1
Vieri Verze
Updated at 2022-02-12 10:09:09 UTC
View: 7175   Answer: 1
Whisper temperature and solar data availability to ITTT
August Divjak
Updated at 2022-02-11 18:31:44 UTC
Whisper temperature and solar data availability to ITTT or another application so I can trigger events on Leviton system.
View: 6865   Answer: 1
Adding a Whisperer to more than one zone
rgbelli
Updated at 2022-02-08 23:01:43 UTC
I currently have one Whisperer for a single zone that covers lawn. As I have 4 lawn zones can I add the lawn Whsiperer to all 4 zones?
View: 8105   Answer: 1
I can’t seem to be able to reschedule my program
cmeital
Updated at 2022-02-07 21:51:50 UTC
View: 6461   Answer: 1
Marcos De Maria
Updated at 2022-02-07 19:44:16 UTC
Buenas ! No logro que prenda el riego .. si ven en la
Foto tengo una electro válvula roja .. para un lado funciona el llenado de la pileta , para el otro el riego x manguera .. en 0 Que es donde está en la foto debería darle la orden la computadora para que encienda la bomba y empiece a regar q estoy haciendo mal ??
View: 7167   Answer: 2
Viento
Helidoro Sánchez
Updated at 2022-01-27 20:48:39 UTC
Gracias,
View: 7388   Answer: 2
Wessam Elbaz
Updated at 2022-01-26 21:28:38 UTC
View: 6557   Answer: 1
Programación
Helidoro Sánchez
Updated at 2022-01-23 09:55:54 UTC
View: 7115   Answer: 1
Pixie smart timer battery not charging
Becky Aquino
Updated at 2022-01-23 00:57:20 UTC
Anyone have an issue with the pixie battery not charging from the unit using solar? My battery level is down to 19% and I live in Hawaii, lots of sun. Not sure if I did something wrong.
View: 8304   Answer: 1
Jamie Campbell
Updated at 2022-01-16 22:09:35 UTC
Every time I go to login to the app, it crashes back to the iOS Home Screen. I’m running iOS 15.1.1 on an iPhone mini. I have tried deleting and reinstalling the app several times and the app works until I put my login details in, then it crashes.
View: 6864   Answer: 2
