How to connect to Google?
Sheryl New
Updated at 2021-10-20 19:28:25 UTC
I can't connect to Google
View: 7013   Answer: 1
Michael Landesman
Updated at 2021-10-17 21:31:54 UTC
View: 10817   Answer: 1
Smart watering
Alisa Benningfield
Updated at 2021-10-17 04:02:18 UTC
View: 6510   Answer: 1
Irrigation systems disappeared
Richard Miles
Updated at 2021-10-17 02:07:50 UTC
I upgraded to a new iPhone and now when I log into Netro no systems appear. I have two irrigation systems functioning but they do not appear in the app
View: 8163   Answer: 1
Can’t run sprinklers manually
plumberman
Updated at 2021-10-15 18:03:25 UTC
View: 7576   Answer: 3
Sprinkle head
Kelsie Nguyen
Updated at 2021-10-13 13:48:22 UTC
View: 7000   Answer: 2
Patrick Dempsey
Updated at 2021-10-09 18:22:25 UTC
View: 6523   Answer: 1
Steve O
Updated at 2021-10-08 19:51:30 UTC
h
View: 6800   Answer: 2
Updated at 2021-10-07 05:53:59 UTC
Dear Netro users,
View: 12253   Comment: 0
erwincaps
Updated at 2021-10-06 15:27:34 UTC
Any advice.
thank you.
View: 6529   Answer: 1
Yellow triangle error
James Mershon
Updated at 2021-10-06 12:23:33 UTC
View: 8101   Answer: 1
Updated at 2021-10-05 10:53:54 UTC
View: 8941   Answer: 1
Issue with Smart Watering
Davide
Updated at 2021-10-04 19:13:44 UTC
Hi Community!
View: 8066   Answer: 1
Updated at 2021-10-03 16:59:12 UTC
View: 9126   Answer: 1
Netro sensor stopped working
Lyndon Whyatt
Updated at 2021-10-02 21:03:34 UTC
View: 7237   Answer: 1
Inaccurate readings
Julie Huynh
Updated at 2021-10-02 00:54:34 UTC
View: 7701   Answer: 2
Growbro
Updated at 2021-09-29 23:10:23 UTC
View: 6628   Answer: 1
SteveRTR
Updated at 2021-09-28 18:41:34 UTC
Any help appreciated.
Thank You,
Steve
View: 6728   Answer: 2
Lee Stocks
Updated at 2021-09-25 01:02:17 UTC
View: 8115   Answer: 1
Battery Charging issue
Billy Wood
Updated at 2021-09-23 14:08:21 UTC
View: 7521   Answer: 1
